| | #1 |
| Junior Member Join Date: Oct 2006
| Help with Masco MA50 tone stack
How can this tone stack be altered for more bottom? The amp is a Masco MA50 that has- grid leak input pentode first stage volume control paralleled twin triode tone stack as shown (original) balanced paraphase PI 6l6 x 4 cathode biased with plate V around 400. The amp has new filter caps and .1 mfd coupling caps. See link if the pic fails. http://jdramps.googlegroups.com/web/...kHiY63vV-EanDl Thanks- Jim R |
| | #2 |
I'd perhaps start by weaking the value of the 25K mid resistor (45), then maybe try a larger cap at 24?
| | #3 |
| Senior Member Join Date: Mar 2007 Location: Philadelphia suburbs
"More Bottom" could mean one of two things: 1.) Lower the cutoff frequency 2.) Increase the volume of the Bass making it through the tone stack. I doubt you are referring to #1. The .1uF coupling cap should be plently large to gett all the low frequencies that you need. To increase the amount of bass making it through the tone stack you should probably look at reducing the value of the 270k resistor going into the bass tone knob. That 270k resistor makes a voltage divider with the pot. Reducing the value of the 270k should increase the bass volume a bit. You can also add some series resistance to the treble to change the balance of treble to bass to give the illusion of "more" bottom. |
| | #4 |
Amen, not enough bottom is not very different from too much top. ALL passive tone controls can do is cut, and there is a limit to how much they can reduce their cutting - that is to say they can;t boost anything. SO reducing the rest of the spectrum while leaving hte bottom alone results in the same overall effect.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Simplifying a tone stack? | hanumanlangur | Theory & Design | 12 | 12-22-2009 12:35 AM |
| Tone Stack Location | tyru007 | Theory & Design | 3 | 10-02-2008 06:23 PM |
| Active tone stack? | ricach | Music Electronics | 12 | 08-02-2007 02:05 PM |
| Tone stack question(s) | Fred G. | Theory & Design | 3 | 04-23-2007 04:43 PM |
| Tone Stack Calculator | Stone | Theory & Design | 1 | 03-29-2007 02:33 AM |
