Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 03-24-2009, 07:37 PM   #1
TD_Madden's Avatar
Bad LP Switch?
I just started having a problem with a MIJ (not for export) Epiphone LP Special....a very nice guitar.
The pickup selector switch seems to have gone buggy...when set to select the neck pickup, there's no volume unless the bridge pickup volume is turned up...if it's zero, there's NO sound from the neck pickup. The bridge setting and the combined setting both work as expected...it's only the neck setting that's screwy.
I've eyeballed the wiring in the main cavity and don't see anything strange, but haven't yet pulled the switch.
Is there a test I can do with my meter to see if indeed the switch is at fault?
Thanks in advance.
TD_Madden is offline   Reply With Quote
Old 03-24-2009, 10:48 PM   #2
Pickup Maker
David Schwab's Avatar
Sounds like the switch went bad, or one of the leaves is bent.
They put really cheap parts in Epiphones, so you'd be best off replacing it.
When you have both pickups on, it will work just as you mentioned. Turning one all the way off turns them both off. That's normal for Gibson wiring.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is online now   Reply With Quote
Old 03-24-2009, 11:14 PM   #3
TD_Madden's Avatar
Yes, I knew that when both were on, turning off the volume to one would do that.....I'm wondering why it just failed all of a sudden.
Old 03-25-2009, 05:17 PM   #4
TD_Madden's Avatar
So the next question would be, should I replace it with another (presumedly metric) replacement or drill the hole out for a SAE-spec'd swtich?
Old 03-26-2009, 04:15 AM   #5
First of all, as Daid explained, that effect is normal for Gibson wiring, but THAT can be remedied by reversing the input and output leads on the volume pots. By wiring the pickup hot lead to the wiper, the output is a constant resistance, and alleviates this "problem".
The enclosed "box" switch used in most Asian guitars utilizes small, flimsy internal contacts. If you want a switch that won't crap out, use a Switchcraft toggle as in Gibson guitars.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 03-26-2009, 06:20 PM   #6
TD_Madden's Avatar
I ended-up just pulling the switch and fooling with the leafs until it worked right. I'll eventually replace it, but for now I'm avoiding any drilling.
Thanks.
Old 03-28-2009, 08:39 AM   #7
If you need a switch that will fit and is also better quality, the Allparts switches are great. Much like their longer Switchcraft counterparts, they have corrosion-resistant contact points embedded in the leaves. The stock Epiphone switches don't have that.
http://www.allparts.com/store/electr...00,Product.asp
Plucky is offline   Reply With Quote
Bad P.a.f greenfingers Pickup Makers 16 05-20-2008 10:30 PM
Bad PT? ricach Maintenance, Troubleshooting & Repair 2 02-29-2008 01:26 AM
is this a bad PT?? Alex R Maintenance, Troubleshooting & Repair 13 02-23-2008 12:57 AM
OT bad ? Valvehead Maintenance, Troubleshooting & Repair 8 08-26-2007 08:44 AM
