Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Conversions
Old 03-25-2009, 02:47 PM   #1
Old Amps, old caps.
I have a Marshall 2040 Reverb Artiste 50watt 2 x 12 combo that I bought new in 1972 - yes, I'm an oldfart. This amp is 37 years old and has only ever had one repair when the bias rectifier died in 2002 and the EL34's became toaster elements - briefly. It has spent most of its life under cover and only been used in anger for something like 48 hours in total over it's lifetime - are the filter caps likely to be near death? Do electrolytics need to be powered up to deteroriate?
GraemeSP is offline   Reply With Quote
Old 03-25-2009, 03:23 PM   #2
Supporting Member
Quote:
Originally Posted by GraemeSP View Post
I have a Marshall 2040 Reverb Artiste 50watt 2 x 12 combo that I bought new in 1972...It has spent most of its life under cover and only been used in anger for something like 48 hours in total over it's lifetime - are the filter caps likely to be near death? Do electrolytics need to be powered up to deteroriate?
Hi GraemeSP, and a heart-felt welcome to the forum!
The answer to your first question is yes.
As to your second question, actually, is the other way around, electrolytics deteriorate faster (and can even explode on powering up the amp ) if they're not used for long periods of time, as the electrolyte tend to dry....you could try to "reform" them, but, considering they're 37 years old, I strongly advise you to replace them all, because, even if they don't explode or leak liquid, they could have developed some ESR which would keep them from operating properly.
Hope this helps
Best regards
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is offline   Reply With Quote
Old 03-25-2009, 10:23 PM   #3
Regis's Avatar
Bob is correct, you should replace them. Even if you had been using the amp it's time. There are all kinds of places to get the right caps, Ted Weber and Doug Hoffman for starters.
__________________
Stop by my web page!
Regis is online now   Reply With Quote
Old 03-26-2009, 06:37 AM   #4
Thanks guys - I would have just plugged in and prayed. I'll sort out some new caps.
Filmosound projector amps ("Bernie" amps)? lustandfury Conversions 11 12-09-2008 12:13 AM
NOS caps vs New caps calis Theory & Design 8 11-12-2008 06:38 AM
Are Illinois caps better the Weber-branded caps? Humbucker Maintenance, Troubleshooting & Repair 31 05-12-2008 01:14 PM
swap F&T 32+32uF caps for 50+50uF caps - anyone? HTH Guitar Amps 0 12-25-2006 10:21 PM
New Caps amplover Maintenance, Troubleshooting & Repair 8 07-21-2006 01:53 AM
