Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 03-26-2009, 11:40 AM   #1
Hybrid Guitar Power Amp 45W
Hi guys, I was designing guitar amp for my self, and I need some advice from more experienced guys.
So here is the schematic, please tell me if something wrong or need to be changed?
Here are the questions:
1.Can somebody give me formula for calculating bias current of
MOSFET-s
2.Where to measure it,
3.Could somebody calculate me bias current on the MOSFET's?
Thanks
Hybrid 45W.pdf
mensur is offline   Reply With Quote
Old 03-26-2009, 12:57 PM   #2
Supporting Member
Steve Conner's Avatar
Hi,
1. There is no fixed answer, it depends on temperature, variations between MOSFET batches etc. If you're actually asking "What should I set the bias current to" then the answer is usually about 100mA or so. It doesn't really matter, as MOSFETs have lousy harmonic distortion at all bias levels, unlike BJTs which have a sweet spot of minimum distortion.
2. Measure the voltage across R9 or R10, and use Ohm's Law to calculate the current.
3. No, see 1. You have to adjust it to the proper value once the amp is built, and check that it stays stable as the amp heats up.
Also, I'm not sure an ECC83 cathode follower will give enough current to drive the MOSFETs fully at high frequencies, and I think using a MOSFET for the thermal sensor may be a bad idea. A BJT should work fine, especially if you're using lateral power MOSFETs. If you're using VMOS, then see Rod Elliot's article on the subject:
http://sound.westhost.com/articles/hexfet.htm
Steve Conner is offline   Reply With Quote
Old 03-27-2009, 12:19 AM   #3
MOSFETs do not really need thermal compensation per se as unlike BJTs, they have a negative temp coefficient. I agree with Steve that a BJT would be a better idea for the bias setting device.
octal is offline   Reply With Quote
Old 03-27-2009, 02:24 PM   #4
Supporting Member
Quote:
Hi,
maybe it's only a typo, the schematic is missing a node between R9-R10 ( 2SK/2SJ source resistors ) and the output line IMHO.
I'd try an ECC82/12AU7/5814 as a CF.
HTH
Best regards
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is offline   Reply With Quote
Plugging guitar directly into power amp clintonb Theory & Design 5 03-11-2009 07:35 AM
How to calculate output power for a push pull AB1 guitar amp anson Theory & Design 17 09-11-2008 08:59 PM
The Complete Guide to Guitar and Amp Maintenance: A Practical Manual for Every Guitar tboy Content 0 08-03-2008 10:32 PM
Dukane Power Amp> Guitar Amp? ArnC. Conversions 5 01-31-2007 06:38 PM
Hybrid Amp Diodes adam75dfw Maintenance, Troubleshooting & Repair 1 01-09-2007 04:08 AM
