| | #1 |
| Member Join Date: Dec 2008
| resistor in place of choke
I've got a 500 R/25w resistor in place where the choke would normally go in the B+line. My B+ voltage is only 357v before the resistor. Can I dispense with this resistor to utilize more voltage to the following stages (the resistor drops 62v) or is it needed to serve another purpose other than dropping voltage? Like a CRC filter perhaps? I do have a 470R @ pin 4 of each 6v6 and 1k @ pin 9 of each EL82 (mixed tube power stage).
| | #2 |
Correction... there is only an 8v drop across the 500ohm R. I had my first B+ (to the OT center tap) connected to the wrong end of the first set of series caps. Silly me ! Voltages came up about 10v all around. Still concerned about the low voltage tho. Perhaps the 2 extra (el84) tubes are too much load on the PT. I have 288v at pin 4 of the 6v6s and same with the El82s. Preamp tubes have between 170v and 240v. The amp might sound cool like this ??? I am looking for early overdrive.... even a bit ratty sounding would be cool. My other amp (a silvertone) has very low voltages on the preamp tubes and it sounds kind of gritty as it breaks up. I like it. Would this be mostly due to low voltage? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 5E3 for 6L6 or 6V6 Filter Choke/resistor sw mod | tubeswell | 5 E 3 | 10 | 03-26-2009 07:11 PM |
| choke VS resistor | rymac | Mods & Tweeks | 2 | 10-23-2008 10:27 AM |
| Choke/resistor switch? | daz | Theory & Design | 19 | 10-15-2008 10:35 PM |
| Can i replace choke with a resistor? | daz | Theory & Design | 4 | 05-20-2008 07:48 PM |
| Resistor in series with choke | Paul P | Theory & Design | 10 | 05-18-2008 07:06 AM |
