Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders > 5 E 3
Old 03-30-2009, 06:03 AM   #1
Headroom - 22k dropping resistor
I have read here that a mod for gaining headroom on the 5E3 is to lower the value of the 22k dropping resistor thereby raising the voltage in the preamp section. Has any one tried this? How did it work for you if you did? Before I order parts, what value of resistor works well?
Thanks all
atmars is offline   Reply With Quote
Old 03-30-2009, 08:02 AM   #2
txstrat's Avatar
Generally a higher voltage on the preamp tube plate raises the headroom of that stage and therefore keeping the stage cleaner at the same volume level. The other way round you can turn the volume up a little more before the tone starts to compress.
But I wouldn't expect too much of an increase of headroom overall. More a different tone due to gain.
If you want to try it anyway I would start with a 15k or 10K /2w resistor.
txstrat is offline   Reply With Quote
The Following User Says Thank You to txstrat For This Useful Post:
MWJB (03-30-2009)
5C5 build hum and fried dropping resistor Jason C Debugging Your Build 17 04-10-2008 06:38 AM
Twin Reverb AB763 Dropping Resistor Amp Kat Mods & Tweeks 9 03-20-2008 12:41 AM
Need to change 22K resistor to 27K when changing from 5U4 to GZ34? PeaveyBandit Theory & Design 4 03-19-2008 01:00 PM
Help me find the dropping resistor in Silvertone 1484 IzzyB Theory & Design 3 12-21-2007 04:35 PM
SVT Voltage Mod/Dropping Resistor Amp Kat Mods & Tweeks 9 01-14-2007 04:52 PM
