| | #1 |
| Senior Member Join Date: Jan 2009 Location: Los Angeles
| Tube intercom to SE guitar amp
I have aquired a cute little desktop intercom unit which I'd like to convert into a SE guitar amp. It seems to have no power transformer, a 35w4 rectifier tube, a 50C5 power tube and a 12au6 pre-amp tube. (all are 7 pin tubes.) It seems to have 2 output transformers. I'll try and post a schematic when I have one drawn. Any suggestions on conversion for guitar use? |
| | #2 |
| Junior Member Join Date: Jan 2009
I have one too and thought of making it useful. I've never peered at the guts yet. One is usually very limited in available mods for amps that rectify the AC line voltage. I haven't look up your tube data but I'm guessing that's what you have.
| | #3 |
| Member Join Date: Apr 2008
Careful, those transformerless amps are death traps. Lots of guitar amps & small radios were made like that in the 50's & have have killed a few people! Do search & you'll see what I'm talking about. You can make them safe by using a 1 to 1 transformer. Shouldn't be too hard to convert just make sure you read up on them before you do. I've got a guitar amp but never use it. Some day I'll either grab a 1 to 1 or just chuck it! ;-) Cheers Sean |
| | #4 |
I was thinking today that if I take out the (for my purposes) useless ~4" speaker there should be room for a PT, perhaps a little creativity in mounting will be required. So then it's just a matter of finding a good sounding circuit using 7 pin recto, power tube, and preamp. Got one? |
| | #5 |
| I'd like to convert into a SE guitar amp. I've had a couple 'rubber sneakers' type amps, the chair kept pinching me though, microphone?POWW!Big shot in the face. 'Hook me up to the power supply' also had hum problems, got literally sparky with other guitar hardware/electronics. It seems to have no power transformer, That puts you in direct connection with one of those two top prongs on the AC line, one of those is called hot, it was probably constructed with the intent that no contact with the chassis connected 'gnd' items is possible. a 35w4 rectifier tube, a 50C5 power tube and a 12au6 pre-amp tube. (all are 7 pin tubes.) I have a 50C5 in a 2prong amp, replaced tubes and caps even. I would take a look at the data sheets before choosing a power transformer for this. I bought new tubes and recapped a ''2pronger''. It seems to have 2 output transformers. These are always nice ! Stereo or dual mono amp ? I'll try and post a schematic when I have one drawn. Be sure to unplug AC and Drain DC. Any suggestions for guitar use? Don't plug a guitar in it. |
| | #6 |
| Senior Member Join Date: Feb 2008 Location: Appleton,Wisconsin
Check out this schematic http://www.schematicheaven.com/bargainbin/kent_2198.pdf I have an amp simular to the Kent 2198 amp Ihope i helped Baddog Last edited by baddog; 04-09-2009 at 11:28 PM. |
| | #7 |
You also mentioned 2 output transformers As always be careful. BADDOG |
| | #8 |
| Senior Member Join Date: Sep 2008
just a guess here too. the one transformer should be switched when the talk button is pushed. I've seen old intercoms where the speaker is the mic and the second transformer is to match the speaker impedance to the circuit. |
| | #9 |
| to stingray
I'm pretty sure you're right, stingray. There is a DPDT slide switch marked "talk" and "listen" and the transformers are connected to the switch. I started drawing a schematic, but... I can trace a circuit but getting it legibly on paper is another story. I stopped working on it before I got to the DPDT. But eyeballing it I'm pretty sure that's what's going on. |
| | #10 |
| to baddog
hey baddog, thanks for the link to the Kent schematic. I had a Kent when I was in JR High School - maybe even the same model - the era is right.
| | #11 |
Can anyone explain to me how having a power transformer makes the amp safer? Can one not still get a shock from the voltage on the secondary?
| | #12 |
In theory the chassis is attached to the neutral of your mains. it CAN be reversed screws that attach the chassis to the cab are now at line potential so is the outer sheath of your cable and consequently your strings and anything else connected to the ground on your guitar if you become the conductor between this and a proper ground you get the full 15 amps (or what ever the the circuit breaker is rated at) using an isolation transformer eliminates this situation. the circuit would not complete from the chassis to a different ground. it can only complete inside the chassis. at least this is how i understand it works If I'm off I'm sure someone will chime in Ray |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Converting a stereo tube amp to guitar amp | Rayme | Conversions | 1 | 12-30-2008 06:44 PM |
| 5w tube guitar amp sechmatic | kldguitar | Build Your Amp | 6 | 08-06-2008 01:26 PM |
| Motorola HS475 tube amp into a guitar amp. | Paulinc | Conversions | 6 | 08-05-2008 06:30 AM |
| How to adjust your tube guitar amp | kldguitar | Tubes (Valves) | 18 | 03-16-2008 01:33 AM |
| Converting tube PA into guitar amp | EETStudent | Maintenance, Troubleshooting & Repair | 6 | 12-20-2007 08:33 PM |
