Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps > Repair and Restoration
Old 03-31-2009, 06:17 PM   #1
deluxe reverb ground switch
i have a 1966 deluxe reverb that is missing the ground switch. i don't really need it do i?
yunger is offline   Reply With Quote
Old 03-31-2009, 07:07 PM   #2
ok, i just read an article about "death switches". that's enough answer for me, hah.
Old 03-31-2009, 10:17 PM   #3
Hi yunger; if you have a 3-wire power cord, you don't need the switch. If you don't have a 3-wire power cord, you need a 3-wire power cord ... and still don't need a switch! CJ
capnjuan is offline   Reply With Quote
Old 04-01-2009, 01:17 AM   #4
i hear ya capnjaun. 3 prong w/ no ground switch it shall be.
Stand Alone Reverb - ground loop busted Sir Cuitous Debugging Your Build 25 05-31-2009 07:26 AM
Lifting Ground Loops in a 6G15 Stand Alone Reverb tubeswell Tweed Builders 14 12-03-2008 01:06 AM
Fender Hot Rod Deluxe switch Kekke466 Mods & Tweeks 7 11-07-2008 01:10 PM
Brass Ground plate for Deluxe Reverb - Dimensions? Mandopicker Build Your Amp 5 08-02-2008 11:56 PM
SF Deluxe Rev:cathode bias switch help? Zouto Mods & Tweeks 1 10-16-2007 01:13 PM
