Results 1 to 2 of 2
Thread: Soft/Med/Hard Duet...
    Mar 2009
    13
    I am looking to buy some Tungsol tubes and see where I need to choose between soft/med/hard duet... I am not trying to get the amp to break up too early and I mainly play clean with a little drive at times. Should I go with the soft or med and push the OD a bit with a pedal?
    Thanks!
    Jun 2009
    87
    I think I would suggest a soft or medium (higher tube rating numbers) tube for the outputs.
    Unless you are running the amp at or above full rated output power, the distortion will be produced in the preamp tubes.
    The better clean tones will require more linearity from all the tubes.
  1. mixed triode/pentode in duet PP
    By allsavy in forum Mods & Tweaks
    Last Post: 02-06-2009, 02:50 PM
  2. x4 6L6 OT ok for duet?
    By allsavy in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-03-2009, 12:28 PM
  3. Pickup Building - The Hard Way
    By spud1950 in forum Pickup Makers
    Last Post: 07-25-2008, 04:47 AM
  4. Can you use A hard drive to...
    By Dave N. in forum Fun with computers
    Last Post: 01-29-2008, 03:08 AM
  5. soft startup for preamp tubes
    By Alf in forum Theory & Design
    Last Post: 08-17-2007, 12:22 AM
