| | #1 |
| Junior Member Join Date: Nov 2006
| Mod to basic AC15 circuit
I'm looking to take the normal channel of an AC15 (EF86, 1x12, schem. ver. V-1-5) and pair it with a tube reverb unit, perhaps from a fender, in place of the tremolo channel. From looking at other schematics with reverb it seems fairly straightforward to interface the two: take the dry out from the first preamp stage and mix it with the reverb return through a parallel R and C, like in the fender Pro-Reverb, for instance. I'm not sure how to calculate the power requirements of the Reverb circuit and in turn, not sure what alterations I need to make to the power supply for this to work. Presumably by removing the tremolo channel from the AC15, I would have enough power available to drive the reverb, but that is just an assumption. Can anyone point me in the right direction? Incidentally I'm looking to add a tone control to the reverb, inspired by R.G. Keen, and a master volume pot. Should be a pretty cool little amp if it all works. Thanks for your time |
| | #2 |
as a side note I was just thinking that it'd be cool to have a vibrato modulate the reverb return instead of the overall output. Has anyone ever done this that you know of?
| | #3 |
| Member Join Date: Jul 2006 Location: North Wales, UK
(Iain) My Dad did a custom-build AC30 with switchable vibrato/tremolo and reverb. And a buffered FX loop, because the guy used a WEM tape-echo a lot but wanted it in a loop rather than into the front. IIRC, the normal channel ran to the normal input of the phase inverter, the reverb went to the other side and the vibrato/trem was used as a bias-wiggler on the reverb side. Is that similar to what you mean?
__________________ So B+ is the one that hurts when you touch it, yeah? |
| | #4 | |
| Quote:
Any thoughts on the main part of my post? | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| What Values For Tone Circuit? | RANDY | Theory & Design | 2 | 10-31-2006 02:41 AM |
| Anyone tried EL34's in a 5E3 circuit? | MKB | 5 E 3 | 19 | 10-28-2006 04:47 AM |
| I'm designing a distortion circuit :) | Eternal Dragon | Guitar Effects | 17 | 10-26-2006 07:28 AM |
| Engl Fireball - keeping the basic stuff | blackwood | Theory & Design | 21 | 10-03-2006 01:09 PM |
| 5F6-A circuit never goes to '0" | Roberto Lasco | Maintenance, Troubleshooting & Repair | 9 | 07-09-2006 03:27 PM |
