| | #1 |
| Supporting Member Join Date: May 2006
| What is a good Vgs-off value for JFET matching
I'm working on a Univox Micro Fazer and have determined that the weak phasing is a result of weak JFETs. Everything else looks and works without a problem and I pulled the original 2SK34's and they measured between -0.74v to -0.89v on R.G.'s improved JFET Matcher (IJM). Which I think is not good? So, I bought 50 BF244A JFETs, measured them on the IJM, setup my bench to record values and categorized 3 sets of 4. One particular set has a value of -1.06v. I put these in and the phasing is still weak. So here are my questions 1. What is considered an optimal Vgs-off value (using the IJM) for the standard Phase 90 circuit? 2. Vgs-off means the voltage at which the JFET turns off. If the JFET is biased at 4.5vdc, is the LFO voltage (at the Gate) the control that turns the JFET on and off... I would think the answer is yes! Vgs-off must be the voltage difference between the Gate and the source...correct? 3. If question 2 is correct, then the optimal Vgs-off is dependent upon the sweep range of the LFO... correct? 4. If this is true then the LFO voltage determines the optimal voltage difference between the gate and the source and I should be able to reduce the sweep range to match my Vgs-off values of the JFETS ...correct? I better stop there before I either answer my own questions or drive myself into a JFET induced coma. Thanks in advance, CJ |
| | #2 | |||||||||
| Lifetime Member Join Date: May 2006
| Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
I would say it the other way round. For a given JFET (because matched JFETs are harder to get than a certain LFO voltage swing), the bias voltage of the source and drain in a phaser circuit should be comparable to or greater than the Vgsoff of the JFET. This ensures that an LFO voltage which is equal to the bias voltage from peak to peak can run the JFET from full on to fully off. As a second condition, the sweet spot for Rds variation is smaller than zero to infinity, so the actual desired LFO voltage swing from peak to peak is within the 0-to-Vsource range and centered over the 10k-to-1M range of the JFETs at hand - which varies. I think you're overthinking it. On the microphazer, replace the electros and remelt all the solder joints. Check the Vsource/Vdrain bias voltage, and if it's between 3V and 5V, it's probably OK. Then see the voltages at the peaks and valleys of the LFO. Should be maybe 1-2V wide, and trimmer adjustable from near 0V to nearly the bias voltage. If that all checks out check for drift in the mixing resistors that mix the dry and phased signals. It's not widely known but the cancellation with those resistors has to be really good to get a notch of maybe 20db. | |||||||||
| The Following User Says Thank You to R.G. For This Useful Post: | Enzo (04-04-2009) |
| | #3 |
Great post RG, I enjoyed that.
| | #4 |
Thanks for the explanation RG. You cleared up a lot of questions. However, the original question, What is a good Vgs is still not clear but you answered that by stating it not possible to answer. I'll go with hands-on learning for now. I got the fazer to work and I have to say it sounds superb. Using the BF244A's (with the -1.06v Vgs) I compared the results with the original 2SK34's and the exact matched set (BF244A's) sounded much better. You were right, there were multiple problems and I suspected that but didn't realize the stomp switch was one of them. The stomp switch would work intermittently and once I replaced it the pedal worked a lot better. It was probably adding resistance to mixing resistors like you stated? When I compared the original 2SK34's to the matched BF244A's (and the circuit was operational), the 2SK34's weren't as expressive or didn't have as much of rotational pulse as the BF244's (at least to my ear they didn't). I probaly could have gotten away with the phase shifting effect they produced, but when the BF244A's were used, the phase shifting was much better...more of a deep pulsing and thumping sound. I also replaced all of the caps (I did this early in the repair) and re-flowed the solder on many joints. So, what have I learned: 1. BF244A's will work in a phase shifter (when matched using the IJM). I will assume that BF244B's and BF244C's will work as well. 2. A Vgs value of -1.06v (in and around this value) is OK to use in phase shifters. 3. It is best if all JFETs are closely matched (but RG's "JFET Matching for Effects" paper states that fact) 4. I now look at the JFET (in phase shifting circuits) as a water valve with the flow controlled by the LFO. The JFET is turned on to allow current flow then as the LFO sweeps the valve is shut off and this happens in unison with all JFETs in the circuit. Thanks again RG! CJ |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Switching a BJT for a JFET | bluefoxicy | Theory & Design | 7 | 06-04-2008 12:54 AM |
| JFET trouble (IM A NOOB) | stratman672 | Guitar Effects | 3 | 05-31-2008 04:07 AM |
| Quick jfet question... | Colonel_Sanders | Theory & Design | 8 | 04-25-2008 12:54 PM |
| Power jFET | Angelo Skouras | Theory & Design | 5 | 09-04-2007 11:46 AM |
| good matching jazz bridge pickup for p-bass | Marco Pancaldi | Pickup Makers | 0 | 01-14-2007 01:25 AM |
