Results 1 to 24 of 24
Thread: 5E3 Build Blowing Fuses
    Nov 2006
    16
    Ok, I finished it, but it won't start. In fact, it is blowing fuses. I turn it on, and test lugs 4 and 6 on the rectifier tube socket, and the MM averages about 450-700v. And then, the fuse pops. Any ideas what could be wrong?
    BTW, this is with no tubes installed.
    Senior Member Mars Amp Repair's Avatar
    Sep 2006
    Englewood, CO
    810
    5e3 blowing fuses
    Hello,
    If the 5E3 is like the schematic listed in Schematic heaven, then you're exceeding the ratings of the filter caps . The filters are rated at 450VDC. They must be getting hot before the fuse blows, too.
    I would have to guess you have the wrong PT for that unit, if once again it is like the schematic on schematic heaven for the 5E3. glen - mars amp repair
    Nov 2006
    16
    I was using the 5E3 weber kit.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,250
    I don't think he'd over voltage the caps with the rectifier tube missing.
    If it blows fuses with no rectifier tube, then one or more of the secondaries is loaded down too much. Or the power transformer is defective. I'd bet on something you wired. I would look carefully at the heater wiring. Make sure you didn't ground both sides of that.
    Also, make sure neither pin 4 or pin 6 of the recto socket is grounded. A stray bit of solder or of wire ends could do that.
    If nothing else, disconnect the power transformer wires from the recto socket, from the heaters and from the recto heater. We want all those wires not connected to ANYTHING. If it still blows fuses, then we have to suspect the transformer. If it holds a fuse that way, then reconect the HV wires to pins 4 and 6 of the recto. Obviously have the amp unplugged from the mains while rewiring.
    If it blows a fuse now, then something about the socket and wiring is bad. If it still holds a fuse, then reconnect the recto heater wires. Again if it mow blows fuses, we know where the problem lies. If it still holds a fuse, we move on to reconnecting the tube heater wires. If one of these steps revealed the problem area, then we know what area to search for the problem. And if we get it all back together and it no longer blows fuses, we have bot only cured the problem, but we also learned it must have been something in the wires.
    Jun 2006
    California, USA
    1,694
    Quote Originally Posted by Munga View Post
    … averages about 450-700v. BTW, this is with no tubes installed.
    You are measuring the AC voltage of the end to end HV secondary. 450 to 700V is a very wide range. 700 is a bit high and 450 is way low. You should get a steady reading unless something is wrong with your meter or the transformer. With no tubes installed and if you are using the correct size fuse (2A) then I’d say that you either have a short in the wiring or a bad transformer. You could disconnect all the secondary leads and tape them off. Then apply power again. If the fuse still blows then I’m afraid that you have a bad PT. If the fuse does not blow, then carefully check your wiring.
    Good Luck,
    Tom
    Nov 2006
    16
    So, for the first step, according to the layout I provided, disconnect the 2 pure red, 2 pure yellow, and 2 pure green wires? Just double checking. I hate getting stuff like this wrong when I think its right.
  7. #7
    18,250
    Yes, that is what I am suggesting. But first, look over the 6v wiring to see if it is grounded more than one place, resulting in both sides of it grounded.
    The two yellow wires should be the 5v winding for the recto heater. If there are any other yellow wires - like yellow with a stripe - DO NOT GROUND IT.
    If the two green ones also have a green with yellow stripe friend, and he is grounded, then NEITHER side of the 6v should be grounded. The green/yellow is the center tap, and it is normal for THAT one to be grounded. The same for the red/yellow one. But the yellow body wires do NOT go to ground.
  8. #8
    Nov 2006
    16
    Ok, with the help Jim McGee, I have figured out that the PT isn't the problem after all. Yipee! I guess.
    I need some more slowblow fuses. But I am at least happy that it wasn't the PT. After I get the fuses, I am gonna try and rewire the PT leads and see if that fixes anything. Thanks for all of your guys's help!
  9. #9
    Jun 2006
    California, USA
    1,694
    While you still have the PT wires disconnected you have a good opportunity to ohm out the chassis wiring to see if you find a short that you missed by visual inspection. It’s not clear yet if you are using the original heater wiring scheme with one side grounded or upgraded to a grounded center tap arrangement. Which is it?
    Tom
  10. #10
    Nov 2006
    16
    Quote Originally Posted by Tom Phillips View Post
    Tom
    I got a Weber kit, so I am using this layout almost exactly:
    https://taweber.powweb.com/store/5e3_layout.jpg
    Alec
  11. #11
    Jun 2006
    California, USA
    1,694
    Alec,
    OK. That wiring uses a grounded center tap on the heater winding (The green/yellow wire) so with the green leads from the PT disconnected, the tubes removed and the pilot light bulb removed you should measure near infinite resistance between:
    1) The two legs of the heater wiring
    2) From either side of the heater wiring and the chassis
    With the red HV leads disconnected you should measure near infinite resistance between:
    1) Pin 4 of the rectifier tube socket and any other pin of the socket
    2) Pin 4 of the rectifier tube socket and chassis
    3) Pin 6 of the rectifier tube socket and any other pin of the socket
    4) Pin 6 of the rectifier tube socket and chassis
    Hopefully this will help isolate a wiring problem that your eye doesn't catch.
    You may need to wiggle the wiring while the meter is connected if all tests are good on the first try.
    Tom
  12. #12
    18,250
    Just a thought. Make sure the pilot light holder does not touch one side of the green wires to chasssis. In other words, both terminals of the light socket must be insulated from chassis, and make sure the sodler tabs on it are not rotated around so they touch either the frame of the light socket or the chassis itself.
    If one side of the light socket gets grounded, then teh 6v winding will be grounded at both the center tap AND that sode. That is a dead short across half the 6v winding
  13. #13
    Nov 2006
    16
    Ok, heres the progress. I soldered everything from the PT except for the green leads, and no fuse popping. Then I soldered the green leads to the light, and still no fuse popping. Then, I installed the Weber Copper Cap, and a hum started coming from the light, and pulled the plug before the fuse could pop again. This is what happened before. Any ideas?
  14. #14
    Jun 2006
    California, USA
    1,694
    Now that's new information.
    Either the Weber Copper cap is bad or something downline from it is drawing too much current.
    Is the standby switch in the "standby" position when this happens?
    If it is then it's the copper cap or a bad switch (low probability but not impossible)
    If you disconnect the lead from the rectifier socket pin 8 to the standby switch and the fuse still blows, then it's a bad copper cap.
    Tom
  15. #15
    Nov 2006
    16
    Yeah, its in standby. I will test that right now.
  16. #16
    Nov 2006
    16
    Tom
    Ok, I disconnected the lead from pin 8, and plugged it in. The light still makes that humming sound, so it must be the Copper Cap, right?
  17. #17
    Jun 2006
    California, USA
    1,694
    Yep. I think so. With nothing connected to pin 8 there should be no load on the PT secondary and there sould be no loud humming. If that humming is not present when you pull the copper cap out, then I say that it's bad.
    Tom
  18. #18
    18,250
    Pull the copper cap out and measure it with an ohm meter. Is there low resistance between pin 8 and either 4 or 6? Is ther low resistance between pin2 and either 4 or 6? There should not be. if there is, one of the diodes is shorted inside.
  19. #19
    Nov 2006
    16
    No resistance anywhere. A tech suggested I use a diode tester. Theres continuity between 8 and 6-4 but none between 2 and 6-4.
  20. #20
    Nov 2006
    16
    Ok, so here is the dealio:
    I decided to do a quick and easy test by trying to get a 5y3 tube, and seeing if that would solve the problem, and plus, I would probably choose it over the CC anyway, so it wasn't a big monetary deal. However, NOWHERE has them. Finally, I decided to call up the tech who Fender sent me to fix my ****ty Hot Rod Deluxe. Last time I went there he was sort of negative because he was sick of fixing PCB Fenders and Marshalls, and just wanted to work on some "real" amps. However, this time, I went over there and he was really excited that I actually made this amp and had an interest in it. So, he helped me test it, and we came to the conclusion that the Power Transformer is indeed faulty. We used his Variac, and the amp was pulling 5 amps at 120 volts. Basically, what he said was the yellow high voltage wires were shorted internally, and read 100 ohms from lead to chassis. So, I guess I have to call Weber and get a new one. What a drag.
    Anyone have to do similar things with Weber? How is his customer service?
  21. #21
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,911
    Seems like I recall there has been a few other builders having problems with their Weber PTs going bad ... Check their BBS.
    If it was a new build and you are sure it was wired right, I'd just tell them you want a new one.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  22. #22
    Nov 2006
    16
    Quote Originally Posted by Bruce / Mission Amps View Post
    I did, and they sent me a new one no questions asked. Just got it in the mail. Thats some of the best customer service I have ever seen.
  23. #23
    Nov 2006
    16
    Sorry for forgeting to reply to this thread. It turns out the PT was bad, so Weber sent me a new PT and it was all fine and dandy. I was wondering. How much effect does the tone knob have on the amp? At the moment, it doesn't have that much of an effect.
  24. #24
    Denver, Colorado
    2,911
    I wonder if Weber must have gotten a few tranny clams from his Chinese winder... seems like there has been conversation about a few bad power transformers.
    Yes, if the tone control doesn't do much, it is wired wrong or the parts are misarked.
    It is much more effective on the bright channel.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  1. Ampeg BA blowing xistors
    By kjkovarik in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-20-2006, 11:57 PM
  2. acoustic model 450 blowing fuses
    By wardevans in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-12-2006, 06:44 AM
  3. Weber 5E3 suddenly blowing fuses
    By sparky in forum 5 E 3
    Last Post: 10-03-2006, 03:37 PM
  4. Mesa Mark III blowing caps
    By AtomicMassUnit in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-06-2006, 03:54 AM
  5. Blowing fuses...
    By riscado in forum 5 E 3
    Last Post: 08-21-2006, 03:06 PM
