Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders > 5 E 3
Old 11-29-2006, 07:11 PM   #1
OT w/ multiple secondaries & triode/pentode switching
I am about to build my first 5E3 after having done a couple 5F1's over the last year or so. After swapping a number of transformers on my first 5F1 I ended up settling on Mercury Magnetics irons (if you're gonna experiment, you might as well do it on the small buggers!).
Anyways... I've chosen MM's FTDO-59M OT - this is a '59 Tweed Deluxe OT with dual secondaries - an 8 ohm tap optimized two 6L6's (5k) and an 8 ohm tap optimized for two 6V6's (8k). I figured that it was only $15 more than the basic Tweed Deluxe OT, so why not give it a try? Does anyone here have experience with this OT?
Second question... I've been debating installing a triode/pentode switch in this build. Does anyone here have any experience with this arrangement in a 5E3? How does this affect the tone?
thanks
sean
brainstatic is offline   Reply With Quote
A Home-Made Triode!??! Don Symes Tubes (Valves) 6 03-01-2007 11:32 AM
MARK IV Switching Marix Gregg Maintenance, Troubleshooting & Repair 11 10-21-2006 02:31 AM
Mesa Mark III triode/pentode question AtomicMassUnit Mods & Tweeks 1 09-10-2006 04:51 PM
Sorry for the multiple posts -all I got was a error message Rob Mercure Lobby 0 08-05-2006 01:16 PM
switching between 2 tube heads on one cab per111 Guitar Effects 11 07-03-2006 02:37 PM
