| | #1 |
| Senior Member Join Date: Apr 2007 Location: sydney australia
| rebuilt my 5e3> hum issue
havent been in the 5e3 section for a while. my 5e3 build turned to a spare parts bin after not being used due to the hum, which was too much of a hassle to fix due to my bad choice of a chassis (had a small opening, and my wires were in 3d due to the placement of the board tubes and controls all being on different faces). this made things quite difficult to do any work on it once there were many connections in there. so the other day i decided to rip out the board and all its connections, the sockets and pots and put it into a chassis made from a 150x50mm aluminium extrusion. things fit much nicer. i wired the power supply as a 300vac winding to a bridge rectifier, and then put it into a 47ohm resistor to get closer to the right voltage. there was also a 47uf cap before the 47 ohm resistor. after this it goes into the normal power supply with 16uf caps and 4k7/22k resistors. this was to get rid of much of the power supply ripple, and get some sag through the resistor. i also added a -ve voltage supply so i could put a switch in to switch it to fixed bias. i also added a voltage divider from the last preamp supply to float the heaters at ~40-60v. i only put 2 inputs (1 per channel) and put a switch to link the 2 channels at the input. theres also a switch to change the cathode bypass cap on the gain stage before the PI. having done a few things there that should have eliminated alot of hum i was surprised how much hum there actually was. i did a bit of reading and it seems i need to separate the filter cap ground for the preamp from the others, and i suspected having the power supply ground connected to the leg of the PT bolt could possibly effect hum. this should minimise hum for the amp. the main issue i have with the hum is for the bright channel. the hum is so bad that it is very unusable. i wouldnt be surprised if on full the hum started to distort. the hum comes from before the vol pot, and is alot worse than the other channel. i disconnected the lead going from the coupling cap to the vol control, and there was no hum coming from the channel. the gain stage has the stock shared 820ohm/25uf cathode bias, so its not an issue with that, otherwise it would effect both channels. the plate resistor comes from the same supply as the fender layout, so i dont see how the hum could be coming from there (im sure some does, but not the bulk of it). i've just got a scope, and am a still learning how to use it effectively. i am seeing some hum on the output from the coupling cap (where the lead to the vol pot would be). there is no noticeable hum on the output of the normal channel (i did turn the vol to full so that there was a full 1m resistance to ground across the pot). i've done a bit of chopsticking to the wires going into the tube socket, and there doesnt seem to be an audiable difference. does anyone have any ideas as to what the reason for so much hum on the bright channel? i will get some photos when i get home later. edit: i am using a split grounding circuit of some sort. i have the filter caps and the cathodes of the 6v6's connected to a copper plate that is bolted to the chassis (was connected to the PT connection bolt, but i may move that). the other connections are daisy chained together and connected to one of the input jacks. i hear that daisy chaining isnt the best way, but i've done it before without issues. the main issue i have is the inst channel issue. i want to get that right before doing the minor fixes. |
| | #2 |
"i hear that daisy chaining isnt the best way, but i've done it before without issues. the main issue i have is the inst channel issue. i want to get that right before doing the minor fixes." The hum is proably on both channels, just the EQ of the inst channel makes it more audible. Daisy chaining is not the best way...how long will it really take you to snip the daisy chained wires an run seperate wires to your ground points? Ground the preamp filter to the input jack. Double check for any ground loops components must be grounded at one point only. |
| | #3 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Hi black_labb Got any pics?
__________________ Building a better world (one tube amp at a time) |
| | #4 |
here are some pics. ![]() ![]() ![]() ![]() a few messy points near the output, partially from moving the ground location to the plug input bolt, hoping that was going to help. i rewired some of the grounding, with no noticeable improvement. im sure its better, but whatever is making the hum so bad is masking the minor fix. i didnt go completely star, but the daisy chains now only link a couple components (ie the vol pot's grounds, the 1st stage cathode, the 2nd stage cathode + preamp filter). i think you may be right mwjb, it could be the TS on the bright channel making it seem louder, as both are quite bad i checked for other ground links on a couple of the ground wires in the preamp when relocating them. didnt find any ground loops there. i havent been able to find any other issues thus far. my only 2 ideas for the issue atm are (aside from me missing a ground loop) 1. my method of floating the heaters (a voltage divider from the preamp power supply 220k-56k to get ~45v) is inserting an ac signal into the power supply. i am quite sure the 56k from the heaters to ground is the only connection. i measured 50k from one side of the 56k to ground. 2. the chassis is a big ground loop???? the chassis has open ends as it was cut from an extrusion, could this make it a big ground loop? thanks for the help guys. |
| | #5 |
| Supporting Member Join Date: May 2006 Location: Texas USA
Daisey chaining is actually the best way but if you have a ground at the input jacks AND at a transformer bolt on the rectifier end, it's hum city. Look at the hum with your scope. Is it 50Hz or 100Hz? A 100Hz buzz comes from grounds in the power supply and rectifier circuits but a 50Hz hum can come from the heater supply and lead dress. The preamp filter cap should be grounded at one of the preamp tube's cathode resistors. Ground for the volume and tone controls should go to the 2nd stage cathode ground. A grounding plate is usually a disaster.
__________________ WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel. |
| | #6 |
Try either 1) a split-ground, or 2) maybe lifting the ground return path from the input socket ground and inserting a .01 - .1 uF cap to bridge the ground return path to the input socket ground (whilst keeping the other ground at the PT bolt). (This option was suggested to me a while back by Simcha (formerly Stephen) Delft. I have not tried it myself but it could be worth a shot)
| | #7 | |
| Quote:
i think the hum is coming from the power supply, as its quite bright/raspy when you turn the tone control up. will check the frequency when i have time. would i be better off linking the power supply grounds to the input jack as well by daisy chaining them to the preamps filter cap, and using the ground connection at the PT for mains earth only? i was under the impression that i was using a split ground method, by putting the ower supply and power cathode resistors to one connection, and the preamp connections to another ground connection, but obviously its not working very well. | |
| | #8 |
"i was under the impression that i was using a split ground method, by putting the ower supply and power cathode resistors to one connection, and the preamp connections to another ground connection, but obviously its not working very well." - You have more to worry about than grounding, your layout is not good. I would re-do the board layout, you want components to line up with the tube socket that they feed, especially with regards to grid wires, which should be short. The split ground method works perfectly when properly executed. Don't fret about keeping filter caps on the board, they can run from circuit direct to prescribed ground if necessary. They are taking up room on the board that could be better used by the PI circuit for instance. Those 68K's also, why not mount these on the jack, taking up too much real estate on the board. Your plate wires should not be in close proximity to grid wires, they can be long, pressed down against the chassis floor, sweep them out & round the tube sockets. Your dc biasing of the heaters should not be necessary in a push-pull amp, in any case you want no more than 40vdc. There should be no other ground reference for the heater circuit other than the voltage divider load resistor. Loudthud said, "Daisey chaining is actually the best way". I disagree, vociferously. I have reduced hum in amps on many occasions by doing away with the daisy chain and running ground wires direct from components to specified ground point. |
| | #9 |
just lost a long reply by pressing backspace only to trigger the back button and losing my work. gist was that i wont be redoing the layout atm, as i feel that the issue i have is from before the vol controls, and they are only really effected by the first stage. thats not to say that its not good advice, but i think the more serious issue is the grounding at the input. i may however move the 68k resistors off the board and move the coupling caps across a bit. i would shield the input wires if this is the case. i think the issue i had was that i was using the input jack ground for the ground point (the bright channel, which was the worst offender). i will do a new ground point near the preamp filter cap, so that the grounding currents dont flow into the preamp jack. i will leave the jacks grounded to the chassis, but i may try isolating them if hum before the vol pots is still an issue. the last amp i did was an 80ishw amp which i used tagstrips either side of the tubes, which made the wire runs very short and i ended up with a very quiet amp guess i was pretty lucky to get by with little knowledge. guess its time to learn the details about grounding. if i did redo the amp i would use tagstrips again, only reason i didnt was because i had a fully populated tagboard. i find they make it cleaner and easier to work on, only issue is the aesthetics look a bit cluttered, but it works very well. if i do, i'll need to get some different screws, as the small sheet metal screws dont like going very far into the 3mm aluminium, might just need to use the next size drill sbit though. thanks for the help everyone, i'll post my findings when i finish the rewiring of the grounds and improve the heaters. |
| | #10 |
"i'll post my findings when i finish the rewiring of the grounds and improve the heaters." ...and those plate wires (pins 1 & 6 12AX7).
| The Following User Says Thank You to MWJB For This Useful Post: | black_labb (04-07-2009) |
| | #11 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
Hey black labb Where does the CT of the PT's HV winding connect to? This is the most important ground node in the amp. It should connect directly to the (-) terminal of the first filter cap, and shouldn't be used as a ground bus for anything else. So, HV CT to filter cap negative, and then filter cap negative to the rest of your ground system.
__________________ "Ohhhh miracle bulb shines feebly" |
| | #12 | |
| Quote:
| | #13 |
Steve, he said he wired it for a bridge rectifier - I read that as no center tap.
| | #14 |
im going to redo alot of the layout of the tagboard. i started taking things out and shuffling them around, and also will be using a larger HT tap, as the current tap is giving me 340-350v at the output from the rectifier, which is too low if i want to use a sag resistor. i'm going to try the 0-370v tap (300 was what i was using before) and i'm going to use a 340ohm resistance, and switch a second resistor in parrallel if i want higher voltages. i may put a single tag strip in to mount the coupling caps that go to the power tube grids. |
| | #15 |
Oh, I never noticed it was a bridge rectifier. What I said still stands, substitute "negative terminal of the bridge rectifier" for "PT center tap".
| | #16 |
i've got the amp rebuilt, and i cant hear any hum, but the dropping resistors arent dropping much voltage at all for some reason, and voltages were too high to give a very clean sound. i didnt go any further as it was 6.30 am and time to go to bed. now im up and ready to finish it off. i'll try to figure out why the resistors arent dropping, and i think i'll change the voltage taps with the bias voltage (making the bias input 70vac) and then i'll just use a resistor to drop the bias. i took out the dc elevation from the heaters to save time. not sure if i'll put it back in. im not sure if its as silent as it seems, as the extra voltage has dropped the gain a fair bit i think, but im pretty certain the hum has been reduced alot, but i'll see when its all together properly. Last edited by black_labb; 04-09-2009 at 04:38 AM. |
| | #17 |
now somehow i have 525vdc coming out of the bridge rectifier with 320vac in... with all tubes pulled (yes i measured both of those values, not just reading off the transformers specs). if i figure out why i can name a new rectifier type after me. edit: was some interaction with the bias voltage. Last edited by black_labb; 04-09-2009 at 07:46 AM. |
| | #18 |
anyone have any explanation for why the -ve voltage supply for the bias was acting up? i was using the transformer shown here https://taweber.powweb.com/store/PTGPsch.jpg i had the 70 and 410V going into the bridge rectifier (supposedly 340v, but came out as 320) and i had the 0v going to the bias supply. so what i was using was 70-0-340 (320) the bias supply is a reversed diode into a filter cap. that went to a 22k resistor, a 10k trim pot with the wiper as the bias supply. the other side of the trim pot was connected to ground through a 12k resistor. the only thing i can think of is that the cap opened up (i just realised that there was ~100v across the 65v cap, forgot to put it after the 22k resistor) so i may get a new one of those and wire it correctly. |
| | #19 |
this is annoying. the documentation for this transformer is useless. i plugged the red/yellow tap into the red and got 380vac, so i assumed i got the wrong red tap. switched to the other and get around the same, as opposed to 320v. should of measured them all myself before i clipped and isolated each lead.
| | #20 |
"now somehow i have 525vdc coming out of the bridge rectifier with 320vac in... with all tubes pulled (yes i measured both of those values, not just reading off the transformers specs)." Measure voltages with all tubes installed, with no tubes fitted there is no current load on the PT voltage will read way high.
| | #21 | |
| Quote:
i think i may use a zener for the fixed bias mode | |
| | #22 |
How much B+ are you trying for? You really have to be carefull with tap used for bias. You can easily end up with several hundred volts. When the main B+ is inloaded, the bias supply will act as the low side of the bridge and push the B+ higher than it would normally go. If there is a standby switch, you probably won't have good bias before you turn the B+ on.
| | #23 | |
| Quote:
would a bias supply like this be bad on the tubes, or would they not heat up enough in the time that the bias is developed? i've disconnected the bias supply so that i can get it all running well before messing around with the fixed bias option. the ac voltage going in i used was 320v when disconnected, so it should be somewhere like 300vac loaded, so should be good enough for rock and roll. i'm not going for a copy as you can probably tell, but the 5e3 flavour is nice, and a bit of versatility cant hurt. i'm not quite sure why the amp sounds so quiet, but i'm hoping the voltages will give me a good idea. thanks for the help everyone | |
| | #24 |
there is 0v on pin 8 of the PI tube, so i'd say i'm pretty much running single ended, which explains the low volume. just need to figure out why now. edit: all looks fine, i'm not sure why it is at 0v, but i'm thinking i might install a paul c mod if a tube change doesnt fix it (i'm pretty sure i've already tried different tubes, but i may as well try once more). edit2: installed paulc mod. there is 50v on pin 7, but still 0 on pin 8. i measure 56k to ground from pin 7, so there isnt a short or an incorrect value there. Last edited by black_labb; 04-10-2009 at 05:09 PM. |
| | #25 |
I think you want to use the taps outline in the attached schematic. The B+ will float up to over 500V with no load (because of the bias supply). Not the ideal situation.
| | #26 | |
| Quote:
for a cathodyne PI, the cathode voltage should be 1/4 of HT and the plate voltage should be 3/4 of HT. (i.e.; the cathode voltage should be 1/3 of what the plate voltage is). If your cathode is at zero, it is at ground potential, therefore there must be a short to the ground return path somewhere between pin 8 and the ground. (What's more the plate will be swinging even harder, because the cathode isn't goin' anywhere). So check your wiring again.
__________________ Building a better world (one tube amp at a time) | |
| | #27 | |
| Quote:
thanks for the diagram loudthud. thas just how i had it wired before when it would float to >500v. i'm thinking i may just switch to zener diodes. would a 27v one seem about right for a 6v6 amp on 390-410v on the plates and 340v on the screens? | |
| | #28 |
I think you need to look at it again, because something is shorting. Is there a wire shorting to the chassis off the back of your boogie board?
| | #29 |
could be something like that. maybe the highish voltages form an arc, where the multimeter doesnt go high enough. will check. thanks
| | #30 |
Or maybe one of your spacer nuts on your board is touching the cathode eyelet or something
| | #31 |
found the problem!!! only one of the filament pins is correctly attached at the base!!! resoldering now, but cant test properly as its late at night.
| | #32 |
i resoldered it last night, and it worked. i had put a component lead between pin 4 and 5, and assumed when i soldered pin 4 in the solder had flowed around the lead when i soldered the heater lead to the pin. guess the tube was putting out some signal was due to the heat radiating from the other trode., which also explained the voltage drop (12v it was, looking back i should have questioned why that was so low). thanks for all the suggestions. will post some comments on tone when i get time to play it. |
| | #33 |
just had a better play through it. i am very happy with it. the hum is quite tame and it seems significantly louder than my pp el84 build (based on an ac15 normal channel, both running into the same 2x10). the amp really roars at volume i didnt experement too much with settings, but they seem to be pretty versatile. i had the channels jumpered, with the 2 channels running at 10-11 oclock, and the tone at 2oclock. sounded very good with 2 guitars. one with humbuckers, and the other with single coils. i will post a proper amp thread once i get the amp into a cabinet, and decide on/finish the circuitry regarding the fixed bias mode. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| New 5E3 build...Tone Control Issue | screamin eagle | Debugging Your Build | 19 | 08-29-2008 10:36 PM |
| Issues with a Rebuilt Champ | womantone | Debugging Your Build | 7 | 08-15-2008 01:59 AM |
| some hum in my new 5e3 | rody82 | 5 E 3 | 24 | 05-05-2008 10:49 AM |
| 5E3 Volume Control Issue | cminor9 | 5 E 3 | 3 | 03-24-2008 01:46 AM |
| 5e3 hum problem | tubelovin | Debugging Your Build | 10 | 09-15-2006 10:57 PM |
