| | #1 |
| Member Join Date: Jan 2009 Location: Prince Edward County Ontario Canada
| Mojo 5E3 sound problems
Well, after many delays I finished my Mojo 5E3 kit and I am terribly disappointed. All I get is a very weak distorted sound out of it. I have rechecked all my wiring and solder joins and everything "looks" okay. No visibly cooked resistors or anything like that. I don't have any sophisticated test equipment but do any of you folks have ideas on where and what I should start troubleshooting? The tubes are all good, I tested them in other amps. The caps and resistors were all new with the kit as were the Power Transformer and Output Transformer. I don't know where to start looking. Any help would be appreciated. |
| | #2 |
| Supporting Member Join Date: May 2006 Location: Texas USA
You really need to get a Digital Volt Meter. They can be found for less than the price of a 12AX7. They are invaluable for finding what's wrong. Any splashes of solder floating around in the amp? Remove them! A short at the speaker jack is common as are miswired input jacks. Check for wires that are too long at pots and tube sockets that are touching the chassis. Any splashes or balls of solder floating around in the amp? Remove them The 12AX7 or 12AY7 has two halves. Make sure you see the orange glow of the heater on both sides. Check that pins 4 and 5 are connected together on the socket. Other than that, try taking some pictures. Use a flash or lots of light.
__________________ WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel. Last edited by loudthud; 04-10-2009 at 12:43 AM. |
| | #3 |
I do have a digital multimeter, I just am not sure what to check. I will go through the amp again today and recheck the stuff you mentioned. I can't take any pics right now as my camera is away on a trip, but as soon as it gets back I will get some.
| | #4 |
| Senior Member Join Date: Dec 2007
Check the resistance in the circuit and compare it to the correct values according to the schematic. For example, if some point on the board has a ground wire soldered to it, you should be able to measure close to zero ohms between that point and the chassis. Do the same thing between other points in the circuit to test for proper resistance. You may find a poor solder joint or an incorrect resistor or a wiring mistake.....it happens. Do all of this with the amp power off and unplugged, and the power capacitors drained of all voltage. If everything looks OK, then you can power it up and check voltage at the tube pins and at various points in the circuit to see if the voltage match the schematic. |
| | #5 |
Diablo and Loudthud, I checked for loose solder and all the tube socket connections, as well as input and output jack connections and they all look okay. I then made sure the caps were drained and measured as suggested all the ground points. They are all 0.00 except for the filter caps which read 0.01 which I will touch up and re-measure later. For the next step, I have never measured live voltages in an amp. If you could walk me throught that at some point, then I will give it a whirl. Thanks. |
| | #6 |
| Senior Member Join Date: Jul 2007 Location: San Ramon, CA
I would carefully measure each resistor to make sure that the value is correct relative to the color bands. I have recieved incorrect resistors in the past because the part picker at Mojo (frankly other suppliers too) selected the incorrect resistor. Orange can look like brown, etc. Also, pay careful attention to the power tube cathode resistor and capacitor. (Connected to pin 8 of the 6V6) Observations...when amp is on...does the power tube look like it is red-plating? At this point, it is easy to find out. Just turn the amp on and watch for some time. Note: Not all tubes are equally liked by every amp...simply testing in another amp may not be enough to know that it works under similar load when in the 5F1 circuit. I would try another tube from a known working amp. This is a very simple circuit with few chances for error if proper care is taken. Just work your way back through each connection and you will find the problem. Rarely is it a huge issue...not likely defective transformers. This is the time when you learn the most. Enjoy the troubleshooting. it will serve you well in the future. Good luck.
__________________ Mandopicker |
| | #7 |
Check this thread. Super Reverb Build Problems Do the checks I outlined in post #14. That will make sure the guitar signal is getting to the first tube.
__________________ WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel. |
| | #8 |
Thanks Loudthud, I did those checks and got absolutely nothing. Here is how I did it, so tell me if I did wrong. With power off and no cable I put the red probe from my meter on pin 2 (and then pin 7) of the first preamp tube. The black probe I put onto the chassis. I tried a number of multiples on the ohmmeter but didn't get any reading at all for either input. So that suggests no input is getting to the preamp, yet I do get very low volume distorted signal.?? And Mandopicker suggested I measure all the resistors. Some are fine within a small variance, however the 68k cathode bias resistors read as 34k. The pair of resistors coming off the pilot light should be 100k each and read as 50k each. One 100k V1 plate resistor reads as 98k while the other (also 100k) reads as .1 on the same setting. Same deal with the plate resistors for V2. One reads ok at 58k while the other reads .1 at the same setting. For the 4.7k 5watt resistor, I can't get a reading at all. Last thing, the power tubes are not red plating and I took a NOS pair of Delcos I am saving until I get this working and they worked just the same way. Lit up nice but only a weak very distorted output. The preamp tubes are lighting up on both sides as they should. That is all I have tested so far and I do appreciate all your advice. What might I try next?? |
| | #9 |
| Senior Member Join Date: Oct 2006 Location: North Carolina
Here's an idea. Find the wire that goes from the wiper of the tone pot to the grid of the second tube. Unsolder it from the tube. Take a spare 1/4" jack and a couple of aligator leads. Connect the tip to the grid and the ground to the chassis. Hook up your guitar. You should get a good clean tone, not really loud but clean. If so you need to concentrate on the preamp circuit. If not the its in the power amp. That test will basically split your amp into two halves and focus your troubleshooting into a smaller area. Good luck, David |
| | #10 | |
| Quote:
Are you sure these resistors measured 100K? Are they brown, black, yellow or are they brown, black, brown? They are the artificial center tap for the Filament winding. They should 100 ohm (brown,black,brown) not 100k ohm (brown, black,yellow). Also, some resistors can only properly be read when on end is lifted...for the sake of exploration...don't be afraid to lift one end and measure it. Doing so to find a solution can save you MANY a sleepless night. Just talking through the design will help you solve it. P.S. Did you measure the cathode resistor? I think you received a 470ohm 2 watt, perhaps. This bias's the 6V6. Being that the amp is Cathode Biased, follow the wire from pin 8 of the 6V6 to the board to find that 470 ohm resistor in parallel with a cathode cap. (Value of 25uf x 25 or 50 volts.) Continued good luck!
__________________ Mandopicker | |
| | #11 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Read the Jack Darr book - really simple to read, includes chapter(s) on troubleshooting http://www.pacificrecone.com/JackDarrBook.html Firstly you need to check that you are getting a VAC supply from your PT secondaries (i.e.; the HT winding, the heater wining and the rectifier winding, and the bias winding/tap (if your amp is fixed bias)) with the amp switched on. Be careful taking these measurements. Then you switch off, plug in the rectifier (if it is tube rectified), and switch back on and check you are getting a high VDC on your B+ line. If you aren't getting this, it could be one of your filter caps is shorted. Then you switch off, plug in your other tubes, switch back on and check the idle plate, screen and cathode DC voltages of all the tubes. Have your DMM hooked up between the respective socket pins and the amp chassis - you are measuring the voltages from these pins to ground. I suggest you use 'gator clips to secure your DMM, and switch off between each reading. Make sure the clips don't short across to other pins. Also check that your heaters are wired up properly and you are getting 6.3VAC across the respective filament pins on all the sockets. Read the Jack Darr book, do the measurements and report back with all the DC voltages
__________________ Building a better world (one tube amp at a time) |
| | #12 |
Thanks Tubeswell for the link to the Jack Darr book. I'm going to print that out for study in my "library".... |
| | #13 |
Well, I have made some changes on my workbench. I have a much better pair of glasses down there now, and from now on, my charming and talented wife (who backs me up on lap steel) will be checking my resistor choices. Mandopicker, that was an excellent call on those resistors. I had my wife, who sees better than me, check them with me and I had switched a pair of 100k resistors with a pair of 100 resistors. I don't think I can blame Mojo for that error. I made the change and the amp just about blasted me out of the room on 2. Everything seems to work but I want to go back and tidy up some of these changes as I did have it all looking very neat and tidy before this. There is a little hum, but nothing too oppressive. I will try it in the cab with no fluorescent lights around before I decide if it is ground loop issues or what. The big thing is it works and sounds terrific!!! Tubeswell, I do have that Jack Darr book. It was too heavy going when I got it, but I am going to do some checking with it now so I can gain a bit more capability. Loudthud and Diablo gave me some good stuff to think about that will save me hassles in the future. DWHutchens, I didn't get to try your test but it is filed away for future use. To everyone who provided such helpful comments, THANKS A BUNCH. This forum is a pleasure and there are a lot of knowledgeable folks out there who are willing to help. I think I will go out and get a couple of premium beers for later today after I have tested in the cab with its new Cannabis Rex speaker. I am sure I will be back with further questions in future. |
| | #14 |
Way to go! The colors can be trouble...just measure twice and solder once. It has served me well when not entirely sure from visual inspection. Now, have fun make it all look pretty. * Funny, before reading of your success, I was thinking about my suggestion and I actually mispoke about the cathode resistor value...For some reason I was thinking 5F1...in a 5E3 it would probably be a smaller value. Anyway the problems are all solved in the same way no matter the circuit and you did it. Enjoy that new amp. I look forward to following your next build. Yes...there will be more.
| | #15 |
FWIW I check all my resistors with a DMM before I install them, just to be completely sure. (I don't trust that colour system - some peep's colours are different from others)
| | #16 |
| Member Join Date: Feb 2009 Location: SF Bay Area
+1 I measure all the resistors too. The color bands don't always look obvius to me. |
| | #17 |
| | #18 |
I will check resistors and caps before installing them now as well. I will read them more carefully too. I have a bit more work to do on this. The second channel quit after installing the chassis in the cab and I hope that is just a bad connection that I can find easily. It was working on the bench. There is some hum, not 60 cycle but higher pitched. After doing some more reading I figure I have too many ground connections. I want to try running the filter cap grounds, the ground for those artificial centre tap resistors for the Filament winding, and the cap off the ground switch to where I have the PT and the AC line grounded, and maybe leave the bypass caps grounded to the input jacks. How does that seem? (I won't ask how it sounds Other than the hum, which I can't hear when I am playing, the amp is going to sound pretty cool to me! |
| | #19 |
Definitely seperate the preamp cathode/bypass cap ground connections from the power and screen filter cap grounds. Also check the connection at the volume controls for the intermitant channel. This design has interactive volume controls and share a connection wire. One of the connetions may not be soldered effectively. You muight try the chopstick test and poke at it while running to see if you can make the channel come back. (BE CAREFUL and keep your hands out of there.) Drain the FILTER CAPS before doing any major work around those areas.
| | #20 |
Well another disappointment. I installed a terminal strip to do my grounding and moved all the grounds except the preamp bypass caps to it. And nothing!!! Then I noticed the preamp tubes and the first 6V6 weren't lit. A tap with a chopstick on the lower left corner of the tag board resulted in a horrible sound. So I shut it down, drained the caps and I think I will leave it for a couple of days before I desolder and pull out the tag board. At least I enjoyed it for a couple of days, even with the hum. |
| | #21 |
That's to bad...won't be the first time this happens...exactly the situation that leads to those long sleepless nights. I would suggest making the amp work again before removing the tag board. Even so much as just putting it back to the way it was...even with hum...just to make sure you know it works. Something else must have come loose during the last operation. This alone is good reason to remove the board. On the other hand, if you feel that a connection at the bottom of the board is suspect...try the continuity tester of your volt meter first to see if the things that should be connected are. (If you hear the "beep," then there is a connection.) Check the junction of the 2 x 220K resistors and ground. In a standard 5e3, this junction is often connected under the board to the preamp and screen filter supply ground junction. These 2 x 220K resistors, on the other end both connect to the power tubes to pin 5 via a 1.5K resistor. Also...no light in the power tubes...check the filaments...are the heaters working for the preamp tubes? Yours are not wired like the old schematic attached because you use the artificial center tap (2 x 100 ohm.) Check each solder connection. * The photo is of a Deluxe-style amp I built that uses 6L6's instead of 6V6's. Gets agout 35 watts or so. It is a very quiet amp. Not pretty at this stage so early in my building learning curve, but quiet. Note the grounds of the filter caps. Funny it was the second amp I ever built and it fired up perfect first try. It was only after I tried to make it pretty that a similar scenario to your recent issue occurred. Now with almost 30 amps and numerous repairs under my belt, I seem to be a bit more careful. (knocking wood...) Have fun and good luck.
| | #22 |
I realise now that I shouldn't have tried to move all the grounds at once. One at a time with tests in between would have been better. I hope to have a look at it today and do some testing but with spring coming here in the frozen north it may have to wait until tomorrow evening. I hope I don't have to take it all apart. Oh and I did put it all back the way it was and it still didn't work so I hope I just messed up something simple.
| | #23 |
| Anyway, the tone is there and it sounds terrific. It is also way louder than I expected. I have a couple of vintage store bought amps with two 6V6s and this will blow them out the door. Actually louder than I wanted but I am sure that will be fine. A couple more days of work and I trust I will have it licked. The next one I do will come with instructions. |
| | #24 |
| Senior Member Join Date: May 2008 Location: Webster NY
Congratulations RG! I'm going to start working on my kit this weekend. If you have the chance, maybe you can post some pics? |
| | #25 |
Way to go...I knew you'd get it. For the static issue, assuming it is not a sypmtom of a troubled output tube that got stressed because of the original 100k ohm resistor mixup, I would get some real good single strand shielded cable for the volume control connection to the first preamp tube. Be sure to ground the shield at only one side (the volume control ground.) Good move knowing when to say when. It should be smooth sailing and tidying up from here. Have fun and enjoy that amp. Once you start breaking it in (speaker and cabinet) it will sound incredible.
| | #26 |
Mandopicker, here is the wiring diagram I used. When you say the wire from the volume control to the preamp tube, do you mean the wire from the middle lug of either volume to the coupling caps? I am willing to give that a shot although our town of 4000 souls doesn't have an electronics shop, I will find some good wire. I had thought about tubes getting damaged earlier and that was why I was using a pair of newer replacable JJs. I put in a pair of older tubes and yes, the static got less, but even better, the remaining hum just disappeared. It is dead quiet now. Still very loud though! I am still saving my best NOS tubes for when I feel it is really done. I will still twist the filament heater wires, but I don't know if I need to carry on with changing the grounding of the filter caps. I imagine it wouldn't hurt. |
| | #27 |
After looking at the schematic you are using...it reminded me of a photo I found on the web...some time ago. I would like to give credit to whoever shot it, but I do not remember where I found it. (Anyway...thanks to whom it may concern) Take a look. Attach the shielded wire from the far right tab of the volume control on the right...connecting to pin 2 of the second tube. If it was me, I would use 2 more small pcs. of the same wire to connect up with the next volume and tone controls and ground them at the nearest point. Do you see how they share a yellow wire in the photo? All that said...if it sounds great...with just the normal level of hum...and the static is gone...I wouldn't really change a thing. Though shielded wire never hurt if used in the right places.
| | #28 |
Mandopicker, the hum is gone, but there is still some static. I do see now the wiring change you mean and will try that as soon as I can. I am going to check all my grounds and solder connections now as well, but I am really pleased with the amp. ( My wife thinks it is too loud, so it must be okay) I have a 12AT7 in the first position because the only 12AY7 I had turned out to be noisy when hitting low notes. I have a Mullard 12AY7 on the way so that may tame it down a bit. Once the static is gone and the speaker has been used for a few gigs, I think I may sell a few other amps that I won't need (HA!). Thanks for your ongoing assistance. |
| | #29 | |
| Senior Hollow State Tech Join Date: May 2006 Location: Denver, Colorado
| Quote:
I don't know where it was found for general viewing on the Net but it is one of about +80 photos I store on a secure server for use by my 5E3 kit customers. I include that "secret" URL with my 5E3 kits so when needed, my builders can review with me photos of portions of the assembly, procedures, hints & kinks, tricks and other commonly found "troublesome novice builders" issues. | |
| | #30 |
My apologies Bruce. I agree with your ownership rights as well as the concept in general. Do you know if there is anyway to remove the image? Perhaps with some moderator assistance it could be done. Again my apologies.
| | #31 |
My vision isn't what it used to be either, so besides measuring components before putting them in, I check all the soldered connections using the Lo-Ohms function on my DMM. I typically mesure between a component lead on the board and an exposed metal part of a tube socket pin or jack or whatever, so I'm measuring across both solder connections. Usually turns up a surprise or two, even on home-made cables. Unplug & discharge the caps first though.
| | #32 |
| Well I finally got some time to play with the static problem and, using the chopstick method, I found the problem. One solder joint that again wasn't as tight as it should be. The static is all gone, so is the hum and the amp sounds magnificent. I am going to test it tonight between my 94 Pro Junior and my 94 Bassman RI, and I will bet I find it nicer. My build isn't quite as tidy as Blueboxer's, but I am pretty happy with it. Thanks for everyone's assistance!!! |
| | #33 | |
| Quote:
| | #34 |
Congrats! Enjoy.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Wiring OT in Mojo 5E3 | Resonator Guy | Tweed Builders | 0 | 03-10-2009 08:00 PM |
| Mounting Mojo 5E3 Tag Board | Resonator Guy | Tweed Builders | 7 | 02-12-2009 02:58 PM |
| 5E3 build voltage problems- zener? | flatfive | 5 E 3 | 13 | 06-05-2008 10:37 AM |
| Mercury Magetics Transformers...problems, bad sound | AG Amps | 5 E 3 | 7 | 12-24-2007 02:41 PM |
| 5E3 Voltage problems | Watto | Maintenance, Troubleshooting & Repair | 11 | 07-21-2006 12:50 AM |
