| | #1 |
| Junior Member Join Date: Apr 2009
| Peavey Bandit 112 transtube 2001 sheffield spkr
My amp is pissed , the handle has a nut that holds it , it came loose and dropped onto the circuit board, (a little tape would have prevented this) Now it sounds distorted and real low even on clean channel, all the pots function the 3 fuses are fine , and I cannot see any burn marks on the nut or the board so im not sure what happened. I was thinking it was the speaker because I was using a RP-6 through the guitar input and not the effects loop but I checked the speaker out and its fine. I could record and send a sound file (using audacity) on how it sounds now if it would help. TIA !!! The overdrive channel sounds almost okay but not as loud and a weird chorus like decay in the sound.. The clean channel sounds shot , real chorus like and like its on a fuzz box . This sucks !!! Last edited by Billmon; 04-11-2009 at 10:07 PM. |
| | #2 |
| Senior Member Join Date: Jul 2006
Hi and welcome to the forum Billmon. It's not the first time a handle nut has reeked havoc ! Need to work out if the fault is now in the pre or power amp. I'm not familiar with that particular model but I presume it has an effects send and return. Try plugging into the return although faint you may be able to tell if it still has the distorted sound there. Also plugging into the input then feeding the effects send into another amp will tell you if the pre-amp is ok . I suspect the power amp but you will need a multimeter to take some measurements. Is the layout the same as the attached (express Transtube) ? |
| | #3 |
I tried putting a jack in the return no change. I do have a multimeter and I'm pretty confident re soldering if I can locate a blown capacitor. I saw that you could clean the jacks , but it is far from the problem. Is there a way to step by step locate the problem? Not that Ill tottally understand but do you have a parts list on that schematic? Why wouldn't they put tape over the frigging nuts?? LOFNL Thanks for the reply !!! Last edited by Billmon; 04-12-2009 at 11:42 AM. |
| | #4 | |
| Member Join Date: Jan 2009 Location: L. Panasoffkee, FL
| Quote:
__________________ CharlieP Peavey VK 112 2008 Marshall 250 DFX 2007 Met. Red LP Gibson Robot 2008 Faded Cherry LP Gibson 2007 Fender Strat HSS LSR S1 2008 Pearl Gretsch G5120 2007 Black | |
| | #5 |
yeah LOL thats what I did first thing when I got the handle back on . Damn engineers overlooking big potential problems. So this is common???? Im hoping this thread will help others with a problem like this !!! I wrote an email to peavey explaining , hopefully they will help me , I will let you guys know how they handle this. Keep the suggestions coming!! Last edited by Billmon; 04-12-2009 at 03:19 PM. |
| | #6 |
I'm not sure if that was/is the correct diagram for your amp. It's only a layout diagram not a schematic. Peavey should be able to supply you with the correct one. However for starters (if its the right layout) check to see you have the two plus and minus 15volt dc supplys. C79 and C65 should have approx 15v across them. On the layout diagram I supplied they should be on the right centre just left of the bigger caps. |
| | #7 |
Actually they ARE aware of that potential problem. A lot of the amps use T-nuts in the cab, which don;t as a rule fall out. But tape is not the solution either for amps that use nuts. Go to the hardware and get a couple "Nylok" nuts of the appropriate size and thread. These are regular steel nuts, but they also have a plastic insert on one side that grips the bolt threads. They don;t work loose. If you CALLed customer service at Peavey and told them the handle nuts fell into the circuitry and caused trouble, I wouldn;t be surprised if they just sent you a couple nylok nuts. I would bet my lunch money that you have a burnt out semiconductor on the board. COuld be a transistor, a diode, or an op amp IC, who knows?
| | #8 |
there are nylock nuts on it from the factory. How do I check the conductors? by putting the electrodes on either side of the conductor to check voltage?? as per post to check the c79 c65??? thank you. |
| | #9 |
Nyloks shouldn;t come loose. Semiconductors are the transistors and related parts. Your meter has a diode test function, or should. COnsult the owners manual for you meter for how to use that. As to those caps, as he said, see what voltage is across them.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| peavey bandit 112 cutting out | HarryLime | Maintenance, Troubleshooting & Repair | 8 | 10-31-2009 08:24 AM |
| Peavey Bandit 112 Transtube - Dodgy pots? | black_box | Maintenance, Troubleshooting & Repair | 9 | 10-12-2009 01:57 PM |
| Peavey Bandit 112 low volume | porman | Maintenance, Troubleshooting & Repair | 2 | 05-30-2008 08:36 AM |
| bandit 112 problem | JC@ | Maintenance, Troubleshooting & Repair | 7 | 07-04-2007 08:32 PM |
| Peavey Transtube 112 | fxcarden | Maintenance, Troubleshooting & Repair | 3 | 01-19-2007 11:30 PM |
