| | #1 |
| Senior Member Join Date: Apr 2008 Location: PDX
| potted my toroid
got a Toroid Corp. 205.5076 (260/13.5/7.5VAC) PT for $93 off the list price... plan to use it in a preamp, either a Bad Cat xtreme tone, or a Deliverance (from SloClone) Potted it into a SS coffee canister lid I got at target: I put brass bolts and threaded inserts (1/4"-20) in the middle, and sorbothane pads on the base the center bolts are (nonmagnetic) SS, and the dome conducts well through them (<1ohm) is this a problem? Will I need to isolate it from the chassis/ ground? |
| | #2 |
Doesn't matter if the bolts are magnetic, all that matters is if they conduct current. We have mentioned this elsewhere around here. If you bolt a toroid into a chassis and then put a lid on the chassis, if the bolt touches both lid and floor of a chassis, then it represents a turn on the transformer. In that case a single SHORTED turn. If your metal lid conducts to those screws, then you better not let the screws and shell both touch the chassis.
| | #3 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
Yup, you had better make sure the dome doesn't touch the chassis. The rubber feet you put on should already take care of that. Alternatively, use nylon washers to isolate the bolts from the chassis. Heck, you could even do both. As an aside, potting the toroid will have reduced its capacity to get rid of heat, so you'll have to derate it a little, maybe 10, 20%. Shouldn't be a problem in a preamp. I like this idea by the way, I have a huge ugly 500VA toroid that I want to use in a high-power bass amp, and now I'm thinking cooking pots
__________________ "Ohhhh miracle bulb shines feebly" |
| | #4 | |
| Senior Member Join Date: Dec 2006 Location: York Pa
| Quote:
Are you planning on building the whole amp with this transformer or just the pre?
__________________ -Mike | |
| | #5 | |
| Quote:
I remembered this from previous posts, I think I'll just use some glass filled nylon cap screws (2 x 1/4"-20 will be plenty strong) and attach a ground strap inside the rim. This PT will only be enough for a couple of 12ax7s (260VAC/0.1A) so its just a preamp | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Can single coil pickups be potted with thier covers on? | jpm83 | Pickup Makers | 5 | 07-28-2008 10:09 AM |
| Toroid transformer in Hartke HA3500a dead | spider | Maintenance, Troubleshooting & Repair | 4 | 02-24-2007 01:48 AM |
