Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 04-16-2009, 03:59 PM   #1
messing with my marshall valvestate 8080
hi, first time poster, am wondering if this is possible?
i have 2 valvestate 8080 combos, what i want to do is put the speaker from one in to the other (so i have 2 speakers in one amp) in a hope to get more bass when its cranked up.
i understand that with 2 x 8ohm speakers im gonna end up with either 4 or 16 ohms depending on parallel or serial.
so my questions are....
1 would it make any difference to the tone anyway as they are both pretty much the same speaker. (80W 8 ohm celestions)
2 would i need to do something to make the amp and the speakers the same ohm rating, or would 4 or 16 ohms work without compromising volume.
any help much appreciated
jonfoote is offline   Reply With Quote
Old 04-16-2009, 04:10 PM   #2
Since the output stage is Solid State, it is safe to go with 16 Ohms (speakers in series). 4 Ohms may fry the amp unless it says something like "4 Ohm minimum load" on it.
Cheers,
Albert
Albert Kreuzer is offline   Reply With Quote
Old 04-20-2009, 05:32 PM   #3
That thing's going to be pretty heavy with 2 speakers in it.
Gunny is offline   Reply With Quote
Old 04-21-2009, 04:34 PM   #4
I wouldn't bother.....it'll still sound like crap. You need a better amp brutha....
__________________
Gtr_tech is offline   Reply With Quote
valvestate 8080 reverb manson Maintenance, Troubleshooting & Repair 0 05-11-2008 10:10 PM
Marshall valvestate 8080 how to get more reverb korhipt Maintenance, Troubleshooting & Repair 2 04-18-2008 06:13 PM
Valvestate 8080 Troubles WMK Maintenance, Troubleshooting & Repair 6 02-07-2008 01:17 AM
Marshall Valvestate 8080 intermittent volume dips cosrjc Maintenance, Troubleshooting & Repair 2 01-02-2008 11:37 PM
Marshall Valvestate 8080 Muddy, Scratchy and Noisy Pigyboy Maintenance, Troubleshooting & Repair 14 12-10-2007 05:31 PM
