Hi Ray
JM2CW your bright channel won't work unless you switch out the .1uF cap. When you put two or more caps in parallel, it merely sums the capacitances - in this case you'd get .102uF, which is the same as .1uF in terms of what you hear, i.e.; no difference. Why not have just try different value coupling caps there until you find what you like?
LinkBack URL
About LinkBacks
