Results 1 to 8 of 8
Thread: samick system 244 schematic
    Nov 2008
    greenville s.c
    8
    it me again dose anyone have a schematic of the preamp and master of a samick sys 244 mixer and possibly the power supply.i have obtained one of these and am trying to restore it to normal .if so e-maill to kid286@juno.com send in pdf format thanks billg
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,055
    Did you contact Samick and ask if they could send it to you?
    Nov 2008
    greenville s.c
    8
    samick sys244 mixer
    enzeo.yes i did they said they had none and had discontinued this unit back in 2000.had no parts either.i have figured out the power requirments,and have powered up the board,there are two chanels out.if i cannot get a schematic i will draw out one.
    18,055
    Two dead input channels?
    Look for op amps failed. Is this one board or are there channel strips? Strips is easier.
    I'd look at any op amps that look associated with the channels. if the channels are side by side, that might mean an IC was shared by the two channels and the one IC is killing them both. Feel them, hot ICs are usually bad. Check pins 1 and 7 for DC offsets.
    SOmetimes they decouple channels with like 10 ohm or 100 ohm resistors to the power rails. A bad IC on a channel could also take out such a resistor. If power rails to the ICs are missing, follow traces and see if there are any low value resistors in series thart are burnt open.
    I don;t remember if Samick liked to put discrete transistor input stages to the mic inputs. If so check for bad xstrs.
    And of course, if there are insert jacks on the channels, the cutout contacts on them are immediately suspect.
    And more than anything, I find open sliders are maybe the most common reason for loss of a channel.
    Jul 2010
    1
    Please. I need the schematic diagram of the apparatus Samick-244. If somebody can help me I will be grateful. Thank you.
    Sep 2011
    1
    I have received a 244 schematic. If you still need one let me know. I would like to get the replacement parts for the eq controls on the input channel. I have some that are bad.
    All the best,
  7. #7
    Dec 2011
    1
    diagram samick system 244
    Quote Originally Posted by marksullivan View Post
    All the best,
    HOLA. My name ISAIAH. I urgently need the diagram samick system 244. I look a few months ago and I can not, I ask for fafor if I could send you re so grateful. well my mail is: isaiasva@gmail.com
  8. #8
    Jun 2012
    1
    Question Samick 244 power supply
    Quote Originally Posted by Bill Guthke View Post
    i have figured out the power requirements, and have powered up the board.
    June 25, 2012 .... 12:06 am
    I would very much like to hear about the power supply for the PA system 244, 24 channel mixer board. I too, have this same board but need to know what kind of power supply it needs. I'd like to buy one if I could find one, but could probably build one if I knew the requirements of the board. If you've got the unit powered up & running, I would be grateful if you would tell me how you did it.
    Don't know how you'd do that exactly as I'm new here. Peace, MikeL
  1. Italian Made Gaglio Pickups And The Fantasma System
    By spud1950 in forum Pickup Makers
    Last Post: 02-23-2009, 06:31 PM
  2. Maestro Sound System For Woodwinds, Schematic needed
    By pdman in forum Guitar Effects
    Last Post: 09-04-2007, 09:45 PM
  3. Thoughts on PRS 513's pickup system
    By Biarnel in forum Pickup Makers
    Last Post: 08-29-2007, 08:12 PM
  4. What reed system do YOU use?
    By Phil m in forum Pickup Makers
    Last Post: 10-20-2006, 04:26 AM
  5. back plate shielding system
    By scorpio in forum Pickup Makers
    Last Post: 08-18-2006, 04:16 AM
