| | #1 |
| Member Join Date: Apr 2009 Location: Woodland, CA
| has anyone built a 12v or 30v tube amp?
I've stumbled across Sopht's amp site, where the builder has used "space tubes" ??? to build a fully functioning valve amp @ 12v across the board, AKA wall wart power supply. If you have built one, got any pics/vids/suggestions?
| | #2 |
Call me silly, but perhaps a link to the site you mention would let the rest of us find out what you are referring to.
| | #3 |
la link. http://www.sophtamps.ca/mambo/index....tpage&Itemid=1 I'm hoping that more people have built something like this successfully. |
| | #4 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Well the 12V version just ain't my cuppa T (cheap OT?, or having the stages biased badly? something is wrong because the distortion sounds like a buzzing mozzie); http://www.sophtamps.ca/sounds/sopht_12al8.mp3 The 30V one sounds a bit more promising http://www.sophtamps.ca/sounds/sopht_30v_clip1.mp3 The one with the KT88 sounds good (but that ain't a 30V amp) http://www.sophtamps.ca/sounds/good_...lean_strat.mp3
__________________ Building a better world (one tube amp at a time) |
| | #5 |
| Senior Member Join Date: Apr 2008 Location: PDX
Hoffman amps has a tiny 12VAC->240VDC tranny for $22 which can be used to make your typical tube preamp pedal, you'd still need the wallwart though... The old PAIA stack in a box is still available (B+ ~40V ??!!) and has been tweaked a bit here: http://www.guitar-pedals-effects.com/DualTubeSIAB.html found this small PS designed to use tube audio in your car:http://www.audiohobbyist.com/diypart...kit/carpsu.htm Last edited by tedmich; 04-30-2009 at 12:18 AM. |
| | #6 | |
| Senior Member Join Date: Jul 2008 Location: Auckland
| Space charge tubes Quote:
http://www.google.com/search?hl=en&q...=Google+Search "Radiomuseum" is a great reference for tube type info. When repairing such radios it is easier to replace the O/p tube with a FET to drive the speaker. Any tube can be used at low voltage like a space charge type but obviously you ain't going to get great results because of the low peak to peak output. I plan to build a 12Volt tube stereo amp for automotive use and my HT will be derived from a modified 12/ 240 V inverter, just take away the output square wave chopper circuit and you have a power supply 2- 300 VDC and heaps of current available. Such a power supply could be incorporated into a large Guitar amp to make it function on 12 volts, but you would want to have something charging the battery! (alternator) | |
| | #7 |
I was hoping someone HAD built one of these little guys, and had knocked out some of the bugs in it. If the space charge tubes are affordable (since nobody uses them, I imagine), a little 12v guitar amp would be a neat gift to friends who play. I can envision a tiny combo with a 5in speaker. I'd call it "The Smokey Yunick Champ". There's an odd car reference for ya. |
| | #8 |
| Senior Member Join Date: Apr 2007
__________________ -Bryan |
| | #9 | |
| Member Join Date: Jan 2007 Location: Seekonk, Ma.
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Who has built a Q&D2 compressor? | JJGross | Guitar Effects | 4 | 02-05-2009 12:36 AM |
| B&K Tube Tester & output tube question | Chevy | Maintenance, Troubleshooting & Repair | 8 | 12-13-2008 01:08 PM |
| Floating 12V heaters | GainFreak | Theory & Design | 2 | 12-10-2008 12:28 PM |
| Guitars From George & Leo: How Leo Fender and I Built G&L Guitars | tboy | Content | 0 | 08-03-2008 09:32 PM |
| tube amp problem. loose tube maybe? | bumcharge | Maintenance, Troubleshooting & Repair | 5 | 10-16-2006 01:50 PM |
