Old 04-29-2009, 05:12 PM   #1
Vox AC30 RI head with AC on the B+
I have a Vox AC30 reissue head that's fairly new. It has a GZ34 rectifier and switches between 50 (150) and 87 bias loads. There's also an effects loop with a nice bypass switch.
There's a fair amount of AC on the B+ ... it varies from about 300 to 320 volts DC (schematic says 321).
It has a fresh set of JJ tubes (the amp blew a fuse and the GZ34 tested bad) and new power supply caps, but the problem remains.
Here's a schematic
http://www.bnv-gz.de/~ooehmann/schem...e%20Manual.pdf
It occurs with the power tubes in, but B+ is steady with them out.
I tried the old power tubes, and they did the same thing, so there's something in the circuit.
Any ideas would be greatly appreciated!!
__________________
See the birth of a 2-watt tube guitar amp - the "Dyno Tweed"
http://www.naturdoctor.com/Chapters/Amps/DynoTweed.html
PRNDL is offline   Reply With Quote
Old 04-29-2009, 09:10 PM   #2
Could it be the tremolo?
There's a footswitch for the tremolo that I don't have.
Could that cause this?
This is a cathode biased amp.
__________________
Old 04-29-2009, 09:58 PM   #3
Yes - it was the tremolo!
The amp sounds fantastic!
Oh yeah, I found an earlier post that talked about how the standby switch on this amp jolts the rectifier. They recommended not using it. It is between the center tap and ground.
The other thing I noticed is the tone dramatically improves when the impedance selector matches the speaker. It changes from lackluster into a mojo monster.
__________________
How about that Vox AC30? adam32790 Guitar Amps 54 10-03-2009 03:31 AM
help with a VOX ac30 JC@ Maintenance, Troubleshooting & Repair 8 07-07-2008 08:30 AM
VOX AC30 mods Valvehead Mods & Tweeks 6 07-05-2008 07:38 AM
Vox AC30 head layout fabiomayo Theory & Design 12 08-17-2007 05:21 PM
Vox AC30 cc crackling Niels_heirman Maintenance, Troubleshooting & Repair 3 03-17-2007 03:28 PM
