On mixer board alone...
Tested all the diodes "in circuit" using the diode setting on my DMM. Not sure about this test procedure...I probed them all in one direction and then reversed direction and there were no shorts.
Identified pins
pin 1 : ground
pin 6 : -15V
pin 7 : +15V
resistance pin 1 to 6 = 1.6 to 1.7 ohms
resistance pin 1 to 7 = 74K ohms
resistance input channel 1 ground to pin 6 = 11.4 ohms
resistance input channel 2 ground to pin 6 = 11.4 ohms
resistance input channel 3 ground to pin 6 = 11.3 ohms
resistance input channel 4 ground to pin 6 = 11.3 ohms
resistance input channel 5 ground to pin 6 = 11.2 ohms
resistance input channel 6 ground to pin 6 = 11.2 ohms
resistance input channel 7 ground to pin 6 = 11.2 ohms
resistance input channel 8 ground to pin 6 = 11.2 ohms
resistance input channel 1 ground to pin 4 of the (16) RC4558P op amps (two op amps on each channel) = 10.7 ohms to 11 ohms (ohms increased as I got farther away from channel 1 ground)
resistance input channel 1 ground to pin 4 of the (4) other RC4558P op amps = 11.5 ohms to 11.2 ohms (ohms decreased as I got farther away from channel 1 ground)
Tested the two small caps at each channel and they were all consistent.
LinkBack URL
About LinkBacks
