| Guitar Amps General discussion about amps |
| | #1 |
| Junior Member Join Date: May 2009
| Speaker Impedance Advice?
I have an old Leslie Tremolo unit (rotating styrofoam baffle with two speed motor) that I want to box up to make a rotating speaker cab. My question is what speaker impedance should I go with? I'm thinking of tossing a 75W speaker in there, but what happens if I want to power the speaker with an amp that needs a 4 ohm speaker load, or another that wants 8 ohms, or whatever? I know that you need to match the impedance, but am I going to be stuck with using the cab with whatever amp I decide to use it with? Or is there a better way to do this? Or should I just take an amp that I have and move it into the cab with the rotating speaker and make it an all-in-one unit? I'm just looking for different thoughts and advice on this. Ideally, I would like to just have the cab and be able to use it with different amps, but I don't know how to get around the impedance issue. Thanks! -Joe Hart |
| | #2 |
DOn't worry about it. Mount the 8 ohm speaker if you have it. If you use a solid state amp, it won't care in the slightest what you use as long as you don;t bust the minimum. All SS amps are good down to at least 8 ohms, most to 4 ohms. If the amp has a 4 ohm rating, the 8 ohm speaker will draw only half as much power as a 4, but that is only a 3db loss in loudness. Besides, most people playing through a Leslie are not trying to fill a concert hall with it. If you have a tube amp that expects 4 ohms, it won't harm it if you use an 8.
| The Following User Says Thank You to Enzo For This Useful Post: | Joe Hart (05-03-2009) |
| | #3 |
Thank you. That is exactly what I was looking for and couldn't find using Google or the search on this site. Thanks!!!! -Joe Hart |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| very old amp w/non PM speaker. Customer wants PM speaker installed. | tim | Maintenance, Troubleshooting & Repair | 4 | 02-24-2009 11:34 PM |
| O/P tran impedance | alastair_in_oz | Build Your Amp | 18 | 11-15-2008 06:04 AM |
| OT impedance for P-P 6L6's | rf7 | Theory & Design | 4 | 08-25-2008 12:26 AM |
| Dynamic Speaker to Permanent Speaker | alphamarquis | Debugging Your Build | 18 | 01-05-2008 03:03 PM |
| Ascertaining speaker impedance without desoldering anything | pbreyfogle | Tweed Builders | 6 | 07-04-2007 02:42 AM |
