| | #1 |
| Junior Member Join Date: May 2009
| What to build with a Hammond 1750J OT?
My first post... I've got this never-used Hammond 1750J OT (4000 ohms primary, 4 ohms secondary, rated for 35 W) here, and want to build something with it; my building experience is relatively limited (built a JTM45 clone from a Weber kit, did a few minor mods to other amps - like adding a master volume, etc.), so it has to be something simple; and it would be nice if it was soemthing relatively small, since I want to use a combo cab (& 8 ohms speaker) I already have... Tonally, something with a gritty, but still semi-clean tone would be great, at volume levels above "practice"/"bedroom", but not necessarily at the the volume level of a full band with a hard hitting drummer - I've got other amps for that). Here are some ideas: -) Use it for a 5E3 - 4000/4 ohms should work with 2x 6V6, if I use an 8 ohms speaker, right? And the beefier OT might give a bit more headroom which would be a plus in my case... If I use a beefier PT as well, I might even try using that 5E3 with 6L6s instead of 6V6s... -) Or go straight for something simple with 2x 6L6 - like a 5E5, 5E5A, or following Weber's 5E3P Proluxe schematic. But I want to use the 8 ohms speaker I already have in that combo cab, and that would be a mismatch with 2x 6L6 and a 4000/4ohms OT, right? Would that be a big problem? |
| | #2 |
| Senior Member Join Date: Aug 2008 Location: Phoenix
You could use the 8 ohm speaker on the 4 ohm secondary, then the primary would be seeing 8K ohms. 6V6 or 6L6 would run on that. Your just not going to be as linear or have as much power output.
| | #3 |
| Senior Member Join Date: Apr 2008 Location: PDX
well its designed for a Fender Pro-Reverb, Tremolux or Vibrolux
| | #4 | |
| Senior Member Join Date: Mar 2008 Location: Germany
| Quote:
Some soundclips here: Deluxe 6G3 | |
| | #5 |
Thanks, guys!
| | #6 |
Hmm, got an idea: I could build a 5E5, but use 6V6 tubes instead of 6L6 - that way, if used with an 8 ohms speaker, that 4000 / 4 ohms OT should work; I'm wondering whether a 5E5 would be a bit cleaner than a 5E3...? Guess I'm gonna start a new thread about that! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Hammond M-101 What have I got? | Dave Johnson | Conversions | 2 | 12-20-2008 04:44 PM |
| Hammond 1750N...anyone used one | daz | Theory & Design | 12 | 09-29-2008 10:23 AM |
| Hammond M2 series help | Montez | Music Electronics | 2 | 05-27-2008 06:29 AM |
| Hammond 125C for SE use? | gmoon | Theory & Design | 3 | 03-09-2008 10:23 PM |
| best hammond OT for HRDL? | Alex R | Maintenance, Troubleshooting & Repair | 0 | 01-07-2008 06:32 AM |
