Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 05-05-2009, 09:05 PM   #1
Looking for a single triode tremolo circuit for a cathode biased princeton reverb
The title says it all... :-)
I'm preparing a new build.
Based on the princeton reverb, but cathode biased.
Cathode bias and the existing tremolo in the princeton reverb won't work together, so i'm looking for a single triode tremolo circuit for this build.
Maybe you can point me in a direction, because i'm all out of ideas myself...
Thx!
nokaster is offline   Reply With Quote
Old 05-05-2009, 09:44 PM   #2
Supporting Member
GA17RVT trem? You may want to add an intensity pot
__________________
tubeswell is online now   Reply With Quote
The Following User Says Thank You to tubeswell For This Useful Post:
nokaster (05-05-2009)
Old 05-05-2009, 11:09 PM   #3
another option
Here's another option to throw in the mix.
With respect, Tubenit
http://www.schematicheaven.com/voxam...dge_reverb.pdf
Tubenit is offline   Reply With Quote
The Following User Says Thank You to Tubenit For This Useful Post:
Old 05-06-2009, 12:10 PM   #4
I have been reading up on this cambridge circuit and the vox pacemaker is very similar. But the tremolo circuit is a little different.
Depth is connected to a capacitor first in the cambridge, but to a resistor first in the pacemaker.
The osilator cap arrangement is connected to ground in different ways...
Which of both would you prefer?
(I found the pacemaker schematic @ schematicheaven)
thx!
Old 06-29-2009, 10:29 PM   #5
max
Successful mod - cathode biased with vibrato
Hey folks thanks for the tips. I was modifying a 70's PR to be cathode biased and successfully incorporated a modified version of the pacemaker vibrato. I got the best results by using a 1 meg pot for the intensity, and removed the 680K resistor. I only use a .1 cap before the plate and it seemed to work the best.
Thanks!
Max
max is offline   Reply With Quote
Can Cathode Biased ever sound like Fixed? MarshallPlexi Theory & Design 23 03-20-2009 11:56 AM
Post PI MV on cathode biased amp MikeT Theory & Design 5 01-12-2009 11:28 PM
Vibrato with Cathode Biased Deluxe Rvb MikeT Mods & Tweeks 2 09-09-2008 11:03 PM
running Marshalls cathode biased EETStudent Theory & Design 11 04-20-2008 11:15 AM
Power Tubes cathode biased w/ shared vs individual R/C? greg Mods & Tweeks 2 08-13-2007 04:19 PM
