Interesting that matching and correct bias don't always equate to killer tone.
It is possible to provide individual bias adjustments for each valve but maybe a bit scientific for rock and roll!
I suppose having several valves and going through them to find ones with a similar current draw would be advantageous... was just going to suggest you d/l these ball park bias charts.
They are for one valve and if you know the configuration and ht voltage
give a suggested current reading.
Power Tube Bias Charts
Until someone posts with experience with these circuits I suggest you measure the HT and compare your figures with the charts.
LinkBack URL
About LinkBacks
) which is biased at about 125% ( and known to be pretty rough on the tubes ) I'm by no means a "meltdown bias" lover, as I usually bias the amps I repair around 70-80%, which in most cases fits the bill without causing the tubes' premature death, because, as long as the tubes' average PD between "off" and "working" conditions stays around 100%, the tubes are still safe ( they swing to, say, 120% when on and they manage to cool down when "off" at 80% ).
