Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 05-09-2009, 10:14 PM   #1
Homemade Chip Amp Question
I recently salvaged parts from an old car stereo and found 2 TDA8561q amps inside. Naturally, the first thing I thought of was building myself a guitar amp. I have it all connected and working, however, this is a 4 or 2 channel amplifier and all I need is one channel. My question is, what do I do with the 2nd input and output? Is it safe to just not connect them at all? Or do I run the risk of blowing the amp?
Also, since I'm such a newbe at reading datasheets, I was wondering if someone could tell me what the current requirments for this chip at full power would be. I want to make sure I have the proper power supply to power this chip and my preamp at the same time.
The TDA8561q datasheet is here:
http://www.datasheetcatalog.org/data...s/TDA8561Q.pdf
Thank you!!
Wade
wadehavens is offline   Reply With Quote
Old 05-10-2009, 04:39 PM   #2
Supporting Member
loudthud's Avatar
With a 15V supply and 4 ohm load a single channel will draw about 1.6A (rail to rail square wave). A 1.2A supply that can provide 1.6A for short periods should be adequite. The unused inputs and outputs should be left un-connected.
__________________
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
loudthud is online now   Reply With Quote
The Following User Says Thank You to loudthud For This Useful Post:
wadehavens (05-10-2009)
Old 05-10-2009, 10:23 PM   #3
Thank you very much for the info! It looks like I have everything I need to put this puppy together.
Thanks again,
Wade
Whammy 1 Obsolete IC chip cjlectronics Guitar Effects 5 12-11-2008 01:37 AM
LM3886 chip - why no work? Alex R Maintenance, Troubleshooting & Repair 14 07-10-2008 12:29 PM
Homemade Microphone David Eugene Music Electronics 1 06-26-2008 05:45 PM
Help with IC Switch Pops from a DG201B Chip AJH47150 Guitar Effects 2 03-20-2008 01:11 AM
Where to get chip for Ross Phaser? eric Guitar Effects 13 01-07-2008 04:50 PM
