Go Back   Music Electronics Forum > Schematic Requests
Old 05-10-2009, 11:05 PM   #1
Line 6 Spider II 210 Amp
Does anyone have a schematic for this amp? And furthermore, what fuse do I need for it? On the back it lists
110 - 120v = T4.0A / 250v Time-Delay (Is this known as slow blow?)
220 - 240v = T2.0A / 250v Time-Delay
Isn't 240v for European plugs? I assume I need the T4.0A, but all it did was blow.
souldeth is offline   Reply With Quote
Old 05-11-2009, 03:46 AM   #2
Mars Amp Repair's Avatar
Hello souldeth,
Yes, the 220-240 rating above is for countries who have that line voltage. Your Spider needs the T (timed) 4amp fuse. It is of the GMA variety (smaller) & 'T' stands for 'timed' or slow blow.
Chances are that the fuse blew because of shorted power IC's, but you're going to have to try the fuse to be certain. If the fuse blows again, take the chassis out & do a good visual on the IC's mounted on the rear heat sink. If they have any black spewed on the board or look like their sides have been blown off, then you need go no further. They are bad.
A schematic won't help very much as most of this amp is totally digital processing & really unrepairable past the obvious pots & such. The power amp IC's are replaceable, with some special soldering skills being necessary.
Get back with the Forum when you get that far...glen
Mars Amp Repair is offline   Reply With Quote
Old 05-11-2009, 04:44 AM   #3
Yep, that's exactly what happened. I do have the soldering skills necessary, but I'm curious if I should just go ahead and replace both (it looks like there's two, one on the right and one on the left) or the one.
Old 05-11-2009, 01:36 PM   #4
I see that the Spider 210 is a stereo amp, but if you cannot determine if both are bad, might as well catch the other one while you're at it.
If it were a mono amp with 2 poower IC'S, then you would definitely have to replace both IC's as one will blow the other up. glen
Line 6 Spider 212 schematic needed olddawg Schematic Requests 7 11-09-2009 11:26 AM
Dead Line 6 Spider II HD cav3man Maintenance, Troubleshooting & Repair 1 05-09-2009 12:36 AM
Line 6 Spider III 30 amp....how the heck do you remove the amp from the cab? tim Maintenance, Troubleshooting & Repair 2 02-26-2009 02:12 AM
Help choose Between Fender Frontman VS Line 6 Spider III klandestino Guitar Amps 3 03-08-2008 07:48 PM
Mm 210-65 tommy d Maintenance, Troubleshooting & Repair 10 08-16-2007 12:13 AM
