| Guitar Amps General discussion about amps |
| | #1 |
| Junior Member Join Date: May 2009
I bought a Twin reverb and tried to plug a Mic. Sounded great but im not sure if it is ok for the amp,to use it that way permanently..costed me a lot of money and cannot take risks..
| | #2 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
I don't think this should be a problem. People play harp through mics plugged into guitar amps all the time. If anything it would be less abusive than cranking it with a guitar.
__________________ "Ohhhh miracle bulb shines feebly" |
| | #3 |
Use a PA mic like SM57/58, with an in-line, Lo-Hi Z mic transformer (Sure A95UF), plug the vocal mic into the Normal #2 input. Be aware that with the mic in Hi-Z mode the pick up pattern will shut down somewhat, you'll need to be right on the mic, more so than with a typical Lo-Z PA set up, but it will definitely work. I have done this many times with good results. Without the lo-hi Z transformer, you'll still get sound, but fidelity & definition may be poor, things may be overly woolly. Try not to point the business end of the mic at the speakers, keep your body between the amp & mic as much as you can, maybe best to stand a little to one side of the amp. As Steve said, there is no risk of damage to the amp...in fact in the 50's & 60's, before large PA amps became the norm, this is exactly what Fender would have expected you to do. The Normal channel is really a left over from the old "mic" channel. |
| | #4 |
Thank you so much. Now i feel i work safe with the twin reverb but IŽll definetly try the impedance transformer to improve the quality of sound
| | #5 |
| Senior Member Join Date: Sep 2006 Location: Chicago
If you're ONLY using the amp for a mic., it would help to add some sort of tweeter in addition to the 12's for some additional "crispness" & definition for your voice (even a cheap ole' piezo tweeter would help). Then again, if your using the amp for an instrument in addition to a mic........never mind.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 1979 Fender Twin Reverb - can't turn off reverb | pro1911a1 | Maintenance, Troubleshooting & Repair | 7 | 02-02-2009 03:40 PM |
| Reverb Issues on a Fender Twin Reverb | womantone | Repair and Restoration | 15 | 09-26-2008 06:31 PM |
| Help me care for of my 72 Fender Twin Reverb | jlonigro | Maintenance, Troubleshooting & Repair | 2 | 12-28-2007 11:48 PM |
| Fender Twin Reverb II static?? | chrisxx | Maintenance, Troubleshooting & Repair | 5 | 08-17-2007 03:19 PM |
| Fender Twin Reverb | Dano | Music Electronics | 4 | 10-23-2006 11:56 PM |
