Go Back   Music Electronics Forum > Fun with computers
Fun with computers Computer-related issues, like digital recording and stuff like that.
Old 05-14-2009, 05:30 PM   #1
pot taper for diy expression pedal
I'm not sure if this is the right place to post this but I'm building a midi foot controller for guitar rig 3 software out of several momentary stomp switches and what will be either a wa or volume pedal (pot operated) interfaced to guitar rig via a usb gamepad and 2 software apps. 1- "joycur" to map static midi messages to keys on my laptops' keypad (which are in turn assigned to various preset effects switching functions in guitar rig) and works fine.
2- "MidiDriver" to handle CC# continous control. Temporairly I've removed the center stop 2 axis jotstick pot from the gamepad and connected a 100K audio taper pot to try things out. I got it to work marginally well although there is a portion in the middle of the pots travel that seems to lag in the responce curve somewhat like what a center return of the origional pot. In other words there is not a smooth transition throughout the new pots travel.
Since the App I'm using was intended for use with a joystick that the problem is with the software response curve. I have tried other software apps that allow configuration of either center point upward or center point downward that might be usefull but I forget what app that was.
Could choosing a different taper (reverse taper ?) help with the center lag issue?
Is there a proven app out there that can be configured to work out this bug?
allsavy is offline   Reply With Quote
FWIW 1M audio pot taper comparison Five_E35 5 E 3 0 03-02-2009 02:59 PM
Audio taper volume pot issue bhuether Guitar Tech 2 02-27-2009 05:28 PM
expression pedal delb Content 0 02-10-2009 12:13 PM
DIY pedal board Robmosis Guitar Effects 3 02-05-2009 01:30 AM
SovTek Mig 50 pot values & taper guitarslam Repair and Restoration 9 01-03-2008 08:03 PM
