Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 05-17-2009, 02:19 PM   #1
guitar switch popping noise
Is there a trick such as installing a cap to reduce popping noise when switching passive pickups. I've installed a mini DPDT as a volume control by-pass switch and depending on which amp I plug into it makes an audible pop noise.
allsavy is offline   Reply With Quote
Old 05-17-2009, 02:56 PM   #2
txstrat's Avatar
The culprit is the "open" circuit for a millisecond or so. If you put in some resistors the circuit will never be open and therefore wouldn't pop.
See attachment.
txstrat is online now   Reply With Quote
Old 05-21-2009, 09:15 AM   #3
Supporting Member
Hi Matt, (BTW, how r u doin' ? ) hi allsavy,
Matt's solution is an elegant one, for the resistors "work" only when operating the switches.
Probably something like this would work just as well, as the two resistors, though "always there" are big enough not to load the pickup(s) IMHO.
Cheers
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is offline   Reply With Quote
Old 05-21-2009, 10:53 AM   #4
txstrat's Avatar
Hi Bob,
hope you're fine too.
I used your version in one of my amps to switch channels. Works good.
Old 08-20-2009, 09:45 PM   #5
phfobric's Avatar
guitar switch popping noise, newbie
Would it be too much trouble to convert this into a wire diag (I can't read music [quickly], but I can follow chord charts!! )
I rehab'd a Parker P-38 (HSS) with Seymour JB for the HB and Classic Stacks for the SC's. I went for single "A" coil w/DPDT for the JB (a spst would have worked, but I was following a diag). No probs, so far. Then I added the Stacks and DPDT's to split them. Now I get a pop when I use the micro's or the 5-way.
Using a diag (for the slow one[s]), would your "trick" work for me? Many thanks in advance, y'all!
phfobric is offline   Reply With Quote
Old 08-21-2009, 05:42 PM   #6
Pickup Maker
David Schwab's Avatar
You shouldn't get a pop with the 5 way. They are make before break.
You aren't switching the grounds are you? Are all the pickup grounds (bare wire) grounded?
Check over all the ground wires.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Old 08-22-2009, 03:08 AM   #7
phfobric's Avatar
U R Guru
Back to Basics. Satisfactory solder joints 101, and I failed. Luckily I had another chance and I had a humbling coming to me. Need more reps with the soldering iron....NOTHING is popping except when I go the piezos (I can live with that) It's the only gadget making ANY noise (except when I'm playing through them he he)
I'll send you a photo of the finished DYI, a product of your assistance for which I am forever indebted. I am not worthy to change the batteries in your voltmeter, O Guru.
Not that you have the time, phfobe.com
frank
Old 08-22-2009, 06:51 PM   #8
Pickup Maker
Doesn't the piezo have a preamp? How are you switching that with the passive pickups?
__________________
Old 08-22-2009, 07:13 PM   #9
phfobric's Avatar
Parker P-38 rehab
There is a spst toggle 0n/0n/0n (mags, mags & piezo, piezo). I fear I've used old solder (dumb!), so on the way to practice, today, I'm going to grab a solder-sucker. My fellow player has great silver solder, new iron; we're going to clean everything up and start from scratch.
After I got rid of the popping I put it back together, restrung it, and there is a short running through the entire axe. Too much wrong for anything to be right. My bud has a more experienced hand, as well.
Thanks again for your help and interest. I'll let you know how it went, and NOT ask for more advice. I've got to get the BASICS right, first!!
Old 08-23-2009, 04:57 PM   #10
phfobric's Avatar
Contuiing Saga
I REALLY need a wiring diagram for a P-38. Know where I can get one? Fingers are wearing out from searching search engines. HELP!
Everything goes through the Fishman preamp. The input jack goes through it. It looks like the shielding from this 2-cond/shielded wire came loose, from where? I have no idea. If I only had a diagram (Boo Hoo!), "or a brain, a heart, the nerve!" (apologizes to "Wizard of Oz"!)
frank
Old 08-24-2009, 03:36 AM   #11
Pickup Maker
Quote:
Why don't you try contacting Parker Guitars?
__________________
Old 08-24-2009, 04:56 AM   #12
phfobric's Avatar
Re ur RE
I have. Half of the Parker home page links are "404". I used the cust svc link. Says they'll reply within 24-48. I paid for a hand drawn diagram from ManualFox for 6.99. Maybe, I'll get a free one from Parker, too. I started this misadventure Friday evening, so everyone was probably gone for the W/E @ Parker, which doesn't altogether explain why they don't have an assessable database for stuff like this. Maybe they did at one time, but I haven't been on board with Parker very long.
Old 08-24-2009, 05:29 PM   #13
I sent a service request by e-mail regarding my P44 and received a reply within an hour on several consecutive occasions. Perhaps the support folks are into their vacation period?
Mark Hammer is offline   Reply With Quote
Old 08-24-2009, 06:31 PM   #14
Pickup Maker
Was that before or after the company was sold?
__________________
Old 08-25-2009, 02:48 PM   #15
phfobric's Avatar
USMusic responds!!
Got four PDF pages of stuff from "Parker". Someone's still watching the "farm". They said give them 24-48hrs....
I've attached the wiring diagram. Hope it opens! If it does, there is a glaring discrepancy. Regarding the Power Chip, when I first removed the pickguard, I dislodged the shielding from the bottom corner connection going to the output jack. It broke cleanly and it wasn't immediately apparent (no diag); only the red & white were visible. There was a tang of itty-bitty shielding sticking out from the connector. Aha! So, we trimmed the insulation back and reconnected the shielding. The discrepancy is, the yellow coming from the 3-way, instead of going to where it is in the diag, it goes to the corner, where we reconnected the shielding. The piezos have worked fine, before and during the rehab. This is a moot point (if it works, don't fix it!), I reckon, but it bothered me a bit, seeing it like that.
Anyhow, me being clueless, dangerous, I never changed the tone pot to a 500k along with the vol. (D'oh!) So, as soon as I do THAT, then I'll know where I stand. I am confident to go onward through the fog (of rosin "smoke") and complete this project. This config will give me 17 different sounds, between a Strat and a Black Beauty (3 S/C or 3 HBs!).
I'll call it my, Parker Fly See-More P-38 'nstein! Kinda catchy...
joy!
Old 08-25-2009, 04:02 PM   #16
phfobric's Avatar
Like I said, the stuff's in .pdf and all I have is the Reader, and I can't change the extension. If I can figure out a way I'll send it, but duty beckons for now...
Old 08-25-2009, 04:22 PM   #17
Pickup Maker
You can attach PDF files here.
__________________
Old 08-25-2009, 04:29 PM   #18
phfobric's Avatar
Done!
Old 08-25-2009, 09:36 PM   #19
LtKojak's Avatar
Done!
Not likely... try again!
__________________
Pepe aka Lt. Kojak
Milano, Italy
LtKojak is offline   Reply With Quote
Old 08-25-2009, 10:00 PM   #20
phfobric's Avatar
With all due repect
Butt Out, Baldy. Earn your own "thread", and a life. Nothing personal.
Old 08-25-2009, 10:51 PM   #21
LtKojak's Avatar
Take a chill pill, Parker boy.
Only to tell you that you haven't attached any pdfs to the thread.
Also with all DUE respect to you. (=null)
__________________
Pepe aka Lt. Kojak
Milano, Italy
How would you fix this popping power switch? semitone Debugging Your Build 12 10-21-2008 02:08 PM
Treble Control popping noise dpierce05 Maintenance, Troubleshooting & Repair 1 09-11-2008 02:50 AM
Custum Vibrolux Has a Popping Switch jcollins Maintenance, Troubleshooting & Repair 2 10-17-2007 03:35 PM
Odd popping noise casey73 Mods & Tweeks 6 09-09-2007 06:04 PM
peavy classic 30 popping noise vanwaltly87 Maintenance, Troubleshooting & Repair 6 07-13-2007 08:14 PM
