Go Back   Music Electronics Forum > Amplification > Other Amps
Old 05-17-2009, 11:57 PM   #1
Peavey KB 100 how to remove chassis?
UPDATE -- A big never mind. I figured it out. I was just babying it a bit too much. Some of the tolex had bunched up under one side of the chassis, and once I got a small flathead screwdriver in there to flatten it out, I was able to muscle it out of the cabinet. It had nothing to do with the power transformer being in the way.
Does anyone reading this know where I can find any kind of instructions for removing the chassis? I have it all loose, but it sure seems as if it hangs up on the power transformer when trying to pull it out the back.
I'm just trying to get to the pots so I can clean or replace them as needed. They have become noisy.
Thanks,
Rico
Last edited by stratwrassler; 05-18-2009 at 01:04 AM. Reason: Help no longer needed.
stratwrassler is offline   Reply With Quote
Old 08-18-2009, 09:14 AM   #2
booj's Avatar
disconnect the speaker cable. I think it comes out forward instead of backward, or is it the other way round?
booj is offline   Reply With Quote
Peavey Classic 100 help robot_trouble Maintenance, Troubleshooting & Repair 4 05-09-2009 12:44 AM
Clever way to remove Peavey PWR tube board? MJN Maintenance, Troubleshooting & Repair 5 02-09-2009 02:39 PM
line out for peavey tnt 100 kprather57 Maintenance, Troubleshooting & Repair 3 09-02-2008 04:29 AM
Hiwatt Lead 50R cannot remove chassis! lowell Maintenance, Troubleshooting & Repair 0 06-27-2008 05:28 PM
Peavey TNT 100 popping.....? StratTone Maintenance, Troubleshooting & Repair 6 11-09-2007 01:45 AM
