Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 05-19-2009, 01:04 AM   #1
want to build an amp
hello,
i want to build an amp from scratch for a guitar.
i want it to be 6v.
can somebody give me some schemes ??
any kind of information will be very usfull!
thank you !!!!
hj01 is offline   Reply With Quote
Old 05-19-2009, 02:30 AM   #2
Site Janitor
tboy's Avatar
Why 6v?
__________________
-tb
tboy is offline   Reply With Quote
Old 05-19-2009, 10:12 AM   #3
basically because i have a good 6 volt battery.
but i am open to any kind of offers/
Old 05-20-2009, 05:58 PM   #4
Supporting Member
Well, you may need a little more than a 6V battery...
Why don't you share your experience a little, and what kind of amps catch your ear. You will probably be limited to an op-amp/ solid state device with headphones unless you can increase the voltage a little. In high school, I built an preamp out of a dual op-amp (two-stage: gain + EQ) and fed the output to a Pioneer car stereo amplifier running off of a 12V motorcycle battery. 60Watts lasted about 1/2 hour between charges. I quickly learned that plugging into my TS-9 was a better sounding preamp which drove the car amp nicely too. There are so many ways to make noise.
GibsonLover is offline   Reply With Quote
Old 05-20-2009, 09:02 PM   #5
txstrat's Avatar
Quote:
Yep!
txstrat is offline   Reply With Quote
Old 05-21-2009, 12:46 AM   #6
well here is where i started, i opened an old tape and took out the cassette head.instead of the cassette head i made a line in into the tape,pluged my guitar and it sounded great.
the tape was 6 watt and ran of 6 volt battery but i accidentely ruined him.
what i basically want is to make something similar, because in want it to be mobile.
thank you very much for responding! sorry if i wasn't accurate at first.
Old 05-21-2009, 01:17 AM   #7
Marc's Avatar
How about this:
http://www.generalguitargadgets.com/...bc35a68d4e7b6d
Marc is offline   Reply With Quote
Old 05-21-2009, 01:44 AM   #8
0.5 watt is to weak.
looking for ideas amp build mark enger Guitar Amps 2 01-07-2009 03:26 AM
What amp should i build for this tone? daz Theory & Design 1 01-04-2009 04:58 AM
to build a Pre-amp, or maybe an amp? Mysteriphys Build Your Amp 5 11-12-2008 08:17 PM
Suggest an amp to build from.... cubby01 Tweed Builders 4 09-15-2008 03:00 AM
How to start build an amp? Jerzy Drozd Build Your Amp 6 05-31-2007 05:57 AM
