| | #1 |
| Senior Member Join Date: Feb 2007
| Shielding a single coil
Hey guys, I am building a strat for someone who wants single coils but with the least hum possible. He doesn't want humbuckers either. I tried talking him into the Suhr backplate but it was too pricey. That said I am thinking of shielding the coils but I don't know if I should just wrap copper shielding around the outside and connect to ground or should I wrap the inside around the magnets and the outside of the coil connecting both to ground. I would think that shielding inside and outside of the coil would be best although I have just done the outside before with decent results. Has anyone tried this before and if so how did it sound? I also don't want to kill the tone of the pickup. |
| | #2 |
| Senior Member Join Date: Aug 2008 Location: Phoenix
Blocking EMI/RFI noise and hum will require total coverage. Like a base plate with a nickel cover. And yes, it will sound different. There are all kinds of noiseless "Strat" pickups, why bother trying to partially shield? If your playing this into a sensitive input you'll want humbucking "single coil" types, or the backplate.
| | #3 |
I have conductive adhesive shielding tape. I was thinking of wrapping around the coil and connecting another piece from that to the underside of the pickup across all 6 magnets. That should do the trick no? I know it changes the sound but I want to be able to reverse this if he doesn't like it. If I wrap the inside with copper and wind over it I'm screwed.
| | #4 |
| Supporting Member Join Date: Sep 2007
The type of shielding that you are planning to do is good for shielding out electric fields. Humbuckers cancel out magnetic fields. You cannot make a single coil do that. (So-called noiseless single coil pickups are some kind of humbucking design that fits in a single coil slot.)
| | #5 |
Dummy coils can be your friend, but a lot of folks have unrealistic expectations about them, and occasionally counterproductive mindsets about what a dummy coil has to be. The advantage of the Suhr system is that the hum-rejection is decent without incurring a tonal penalty. Does hum-rejection need to be "perfect"? Nah. I imagine most players of traditional SC-equipped guitars would be happy (though not necessarily satisfied) with 6db reduction in hum. So, if you can try a few experiments in whipping up your own ersatz Suhr coil on either the backplate or pickguard, why not? It won't be as good as the Suhr coil, but hey 6db less hum is 6db less hum, right? |
| | #6 | |
| Quote:
| | #7 |
| Senior Member Join Date: Sep 2007 Location: Van Nuys, CA
No matter what you do with shielding single coils and the cavities of the instrument, you still have the poles of the pick-up just hanging out there like antennas picking up more than just the string vibrating - ahhh but the tone.......
__________________ "The time I burned my guitar it was like a sacrifice. You sacrifice the things you love. I love my guitar." - Jimi Hendrix http://www.detempleguitars.com |
| | #8 |
| Old Timer Join Date: May 2006 Location: PDX
I've had very good luck with the nickel spray paint on the top and back of the PU as it grounds all the magnets at once. I just wrap a piece of copper tape around the coil and insulate the ends so they don't form a loop. Ideally you'd avoid loops through the magnets and only connect them to the top or the back. Just look out for shorts to the magnets on your inside coil connection.
| | #9 |
| Member Join Date: Oct 2006
Low-impedance! |
| | #10 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| | #11 |
| Senior Member Join Date: Oct 2008 Location: Victoria, BC Canada
I thought this might help. Seems like a pretty easy design. I wonder how strict/specific the patent is on it.
| | #12 | |
| Quote:
The actual invention was intended as a coil embedded in the body around the pickups, but the trem cover coil falls within the invention. The coil is shown round, square or freeform. It says the closer to circular the coil is, the better, and it must be at least 5 times the "average square surface area of a regular single coil style signal picking coil". The dummy coil is said to be "100 to 1000 turns wound with wire gauge #41 or heavier." It goes on that the preferred coil has an overall diameter of 8" and be wound with 200 turns of 36AWH wire. There is more to it than just a coil though, it also has some accompanying passive circuitry. This is listed as a "simplified schematic."
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab | |
| | #13 |
Ok. I just tried shielding the single coils and let me tell you they sounded TERRIBLE! It cut back on the hum a lot, but it sucked the life/tone right out of the pickup. It was as if the low mids were knocked right out which is the best part IMO. I told my customer and he wanted to hear them anyway and agreed they didn't sound as good as the unshielded ones. Once took the shielding off, it opened them right up and they sounded fine. So lesson learned shielding single coils ain't for me. So I think he is going to save a few pennies and go with the Suhr backplate down the road which I think is the only design that makes sense for single coils without altering the sound.
| | #14 | |
Did you remember not to complete the loop around the coil? You do not want a complete path forth the current to flow around. Quote:
| The Following User Says Thank You to Mike Sulzer For This Useful Post: | StarryNight (05-30-2009) |
| | #15 |
| I'm not sure I follow you. I wrapped the coil with paper tape and then I wrapped copper foil around that and soldered it to ground. Are you saying I should leave a gap or a break in the copper somewhere around the coil? If so wouldn't that defeat the purpose of shielding it? I'm a newbe when it comes to shielding pickups themselves but I have been shielding guitars for 20 years. It sounds like there is a different method for pickups?
| | #16 |
Voodoochild, do a quick search of the term "eddy currents" to get the lowdown. You don't want a continuous loop of metal around a pickup. An overlapping loop that's insulated between the ends is going to still give you 100% coverage (on the sides anyway) and there won't be a major sucking path for the eddy currents to form. (They will still be there in the foil but you will have stymied them somewhat). Eddy currents = significant losses at higher frequencies. Not so sure about your low-mids -though that may be an auditory sensation from losing highs... |
| | #17 | ||
| Old Timer Join Date: May 2006 Location: Boston, MA area
| Quote:
Quote:
A nickel-powder loaded conductive paint cavity shield has too high a resistance (~20 ohms) for eddy currents to matter as well, even though the resistance is low enough to be totally effective against electrostatic fields. | ||
| | #18 |
| And it is very easy to understand why the distance makes a difference. What you need to do is "add up" all the field lines that pass through the conducting loop. Field lines are continuous: those that pass through the core loop around and come back in the other end. But if your loop is big enough to include a field when it loops around as well as when it passes through the core, the effect of that line cancels out. That is because the line points "up" once and "down" the other time. If the loop is big enough, nearly all lines are included both times.
| | #19 |
So it's better to shield the cavity than the coil? Or it's OK to shield the coil but you just have to be careful about how you go about it?
| | #20 |
| | #21 |
Thanks for all the good info. I always like to keep it old school and simple, and this time I stepped out on a limb and broke it. But now I know. I'll have to try it again soon and do it right next time.
| | #22 | |
| Quote:
Here's a good way to do it. This is a Duncan MM pickup. Note the way the foil is wrapped around the coils... they have it closed in the back, and open in the front where the poles come out. This grounds the poles, and the magnets in this case are glued to the foil. Of course if you are using rod magnets, than that doesn't apply. This shields the coil, while not being a closed loop. It doesn't even go around the coil in the same direction the wire does. I completely shield my pickups, but I do something different for shielding. I can hold them a few inches from my CRT monitor without all that usual buzzing you get.
| | #23 |
So I tried this again on my own time to see what effect it had. I finally got the technique right by insulating the ends so it didn't create a loop. I found that it still took something away from the pickup that made it sound different in a worse sorta way. It was even more noticeable when I shielded across the magnets. I think I would rather stick with the old school single coil design without shielding. It just plain sounds better to me. On a positive note I think this will get me experimenting with dummy coils isolated further away from the single coils to reduce hum without noticeably changing the tone.
| | #24 | |
| Quote:
A dummy coil can work well, but it is not the same as a shield. The shield is for electric fields; the coil for canceling magnetic fields. In my experience, a minimum amount of shielding is adequate for the electric fields, and the cancellation of the magnetic field is more important. So I think that you are headed in the right direction. | |
| | #25 |
Voodoo, I say skip the foil and try the paint, you might just like that better. |
| | #26 | ||
| Quote:
Quote:
| | #27 |
| Supporting Member Join Date: Jul 2008
| BTW Joe - I tried that MG Chemicals Nickel Super Shield you recommended .. WOW! I'm now on my fourth can. I made a batch of guitars this week with P-90's, played them sitting on top of the amp, with a 4 ft floresant light over head and I couldn't detect hum at medium volume. I was blown away at how quiet the guitar was. I had the guitars setup RWRP and it really didnt need it. Thanks for the recommendation.
| | #28 | |
| Quote:
Priming the raw wood cavity before applying shield paint may reduce shielding paint consumption enough to be worthwhile. The dried paint film is thin and somewhat delicate, so for long life the electrical connection to the film should involve a wide area of contact, such as a brass washer, versus just a wire and a small wood screw. Another good approach is where the film extends out on the surface of the guitar body, with area contact being made all around the routed cavity by some metal foil attached to the underside of the pickguard. | |
| | #29 |
| Member Join Date: Oct 2007 Location: Roma
| Vodoochild, my 2 cents. this is an article I wrote for an italian magazine concerning Stratocaster shielding, including pickups. It' s in italian, but you should easily translate it using Google translator. Pictures are also quite eloquent Hope it can help you. How to shield a Strato |
| | #30 |
| Old Timer Join Date: May 2006 Location: Planet Mongo in the country of PAF
There is a website somewhere that is mostly about making strats quiet, they use something called star grounding I think it is. I did some strat pickups for an up and coming "star" and his tech used star grounding and some other technique he wouldn't tell me about and got the guitar dead silent without screwing with the pickups. I found it: GuitarNuts.com - The Internet Home for Wayward Pickers |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Single Coil with Humbucking Effect | eblock | Pickup Makers | 24 | 06-12-2009 11:43 PM |
| amp overdrive for single coil | chipaudette | Theory & Design | 10 | 01-01-2009 08:17 PM |
| Fine tuning strat single coil pups with a dummy coil? | Silent Bob | Pickup Makers | 0 | 11-04-2007 06:15 AM |
| Coil tapped single | Spence | Pickup Makers | 11 | 08-29-2007 01:04 AM |
| single coil magnets in a HB? | franklin01 | Pickup Makers | 8 | 09-24-2006 01:41 AM |
