Old 05-21-2009, 12:51 AM   #1
Help repairing Ampeg 1540 Crossover
Hi, I have this dead Ampeg 1540 crossover , the one in the "fridge size" box with 1x15"/4 ohm spk and 4x10" + Horn ; which can be biamped (2 x 4 ohm separate inputs) or run full range (two parallel 8 ohm input/link jacks)
Itīs been messed up beyond repair, no pad switch, missing pads, rusty worn jacks, the works, but the components themselves (power resistors, capacitor, coil, even the lamp) are healthy.
If I can have the Xover schematic I can draw, etch and build a new board using available switching jacks and those old components.
Thanks.
J M Fahey is offline   Reply With Quote
Old 05-21-2009, 01:17 AM   #2
Here you go. I can make a gray scale copy if this is too dark.
__________________
The Following User Says Thank You to Enzo For This Useful Post:
J M Fahey (05-21-2009)
Old 05-21-2009, 03:00 AM   #3
Hi Enzo, thanks a lot.
Canīt believe it, I thought : "well, Iīll check in a week or so ....", but you answered in 26 minutes !!!! (twenty-six, no kidding).
And that includes searching your undoubtedly vast library, scanning and posting exactly whatīs needed.
The scan is fine, I just needed the schematic.
Although relatively simple, tracing it "from the board" was very frustrating, because the complex switching: in/out , series/parallel, joining/separating grounds, etc. was made through unreliable cracked rusty contacts, and, besides, I canīt get those same jacks in Argentina, so the next best solution was making a new board using pin-incompatible plastic "Marshall jacks".
The 6-pin connector pinout wasnīt clear either, because the cabinet is unavailable for me to test (long story).
Again, thanks a lot.
Old 05-21-2009, 04:34 AM   #4
26 minutes? Darn, I'll try harder next time.
__________________
Old 07-05-2009, 04:53 AM   #5
Ampeg 1540 he Straight wire
Any ideas how I can just straight wire the 4 10's and one 15 straight at 4 ohms?
Thanks,
Jeff
brash is offline   Reply With Quote
Old 07-07-2009, 01:15 AM   #6
I can think of no way to wire five drivers for 4 ohm total. At least not if the drivers are of common impedances like 4 ohms or 8 ohms.
__________________
Old 07-07-2009, 05:39 PM   #7
Quote:
If the four 10's are 8 ohms, series parallel them to give you 8 ohms, then parallel them with a single 8 ohm 15 inch.
52 Bill is offline   Reply With Quote
Old 07-08-2009, 01:24 AM   #8
Duh...
Having a senior moment, I guess.
You are right, but the speakers would then not share power equally. I was trying to come up with some way they would see equal power. But I guess that arrangement would electrcally be the same as a 4x10 cab and a 1x15 cab stacked.
His drivers are already 4 ohms though. Can;t get 4 ohms from five 4 ohm drivers.
__________________
Crown CE2000....anyone actually repairing this junk? Gtr_tech Maintenance, Troubleshooting & Repair 8 03-27-2009 05:36 PM
Help with repairing old MXR script phase 90 Elvisofnazareth Guitar Effects 10 12-28-2008 08:00 PM
Repairing a Bl@nkenshib Sir Cuitous Maintenance, Troubleshooting & Repair 0 04-07-2008 12:25 AM
Repairing a Bl@nkenshib Sir Cuitous Theory & Design 1 04-07-2008 12:20 AM
Repairing 2 Peavey 2000. Andrew58 Maintenance, Troubleshooting & Repair 2 09-26-2007 11:43 AM
