The specs for the NTE is more than enough for the amp, so sure, if it fits use it.
The original markings show how the leads connect. The two yellow are the AC inputs, the red is the + dc output. The unmarked lead is the - dc terminal.
Re-check the new outputs before you power up again. Did you check the driver transistors and the emitter resistors, etc.?
LinkBack URL
About LinkBacks
I found that BR-71A is open...so my question is 2 parts
