Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders
Old 05-21-2009, 11:11 PM   #1
Low Powered Tweed Twin 5E8A
I'm thinking about building the 5E8A, and I'd like to know what's a "good" plate voltage for the original tweed twin. I see the schematic lists 405 volts, but I know that doesn't mean anything. What's typical and where do they sound sweet? On the "57 Twin Reissue", did they use the same plate voltage as the original? Also, did the original 5E8A come with 5881 or 6L6GC tubes?
Diablo is offline   Reply With Quote
Old 05-30-2009, 12:28 AM   #2
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
I like them the best with 6L6GCs, the B+ at or under 420vdc (but above 400vdc) and with the power tubes idling at around 45ma to 55ma each.
I always try to use a NOS 5U4 rectifier.. even the NOS Svetlana 5U4s from the early to mid 80's work really well.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 05-30-2009, 01:41 AM   #3
Thanks Bruce for the info. It's guys like you that make this forum great.
1957 Tweed twin OT, various q's Blue Jim Vintage Amps 2 06-06-2009 11:14 PM
Tweed Twin Output Transformerthinkin rymac Tweed Builders 3 11-12-2008 08:43 AM
5E8-A tweed twin. Volume cuts out at 8 corduroyew Debugging Your Build 2 10-29-2008 05:43 AM
Weber low powered tweed twin kit Ted_Ramey Kit Amps 9 02-22-2008 10:26 PM
1x12" Pro 5E5A or Twin 5E8A? Chris / CMW amps Tweed Builders 9 04-03-2007 04:53 PM
