Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 06-01-2009, 11:34 PM   #1
Formvar humbuckers, anyone?
Anybody wound some buckers with formvar? If so, how does the sound differ from PE?
Zhangliqun is offline   Reply With Quote
Old 06-02-2009, 01:29 AM   #2
Possum's Avatar
You just have to try it for yourself. I tried it and I don't sell pickups made with it, they sound ok I guess. You get a fatter coil which softens it up more than I personally like....
__________________
http://www.SDpickups.com
Stephens Design Pickups
Possum is offline   Reply With Quote
Old 06-02-2009, 02:14 AM   #3
Pickup Maker
David Schwab's Avatar
Quote:
Is that heavy formvar, or regular?
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Old 06-02-2009, 03:37 AM   #4
Possum's Avatar
Heavy, I've also used single and its a softer sound, I don't like it in a neck pickup it kills come clarity for me....
__________________
Old 06-02-2009, 03:38 AM   #5
Possum's Avatar
I meant SOME clarity not "come" clarity
__________________
Old 06-02-2009, 10:31 PM   #6
madialex's Avatar
Dirty ol Possum
madialex is offline   Reply With Quote
Old 06-03-2009, 01:48 AM   #7
Possum's Avatar
Brain fart, I thought I was on the nekked chicks porn site
__________________
Old 06-04-2009, 10:18 PM   #8
Quote:
Double-build, which is "heavy" according to MWS. I'm a formvar virgin but I just bought a spool because I get a lot of requests for formvar Strat pu's but was curious how it would sound in a 'bucker.
Old 06-05-2009, 12:17 AM   #9
Pickup Maker
Quote:
I've never used it. I was tempted to buy a roll one day. I do have some heavy build 45AWG SPN though. That's an odd combination!
__________________
Old 06-05-2009, 04:52 PM   #10
I have used it and it sounds great. You have to pull more tension on the formvar than the PE because the insulation is slick compared to PE which will automatically give you a softer build if you try and keep the tension the same. Once you get the tension right you won't tell a difference between PE and formvar given that the insulation build is the same.
voodoochild is offline   Reply With Quote
Old 06-05-2009, 05:29 PM   #11
But it's not the same build. The formvar I have is double, the PE single. I figure that will put a lower limit on the number of turns I can get on a bobbin but was wondering what else.
Old 06-05-2009, 05:43 PM   #12
In that case it will build up more and yes it will sound completely different.
Old 06-06-2009, 02:54 AM   #13
Possum's Avatar
It will make the coil significantly fatter, the fatter a coil you have the softer it starts to sound, the smaller the coil is the more of the coil that is immersed in the magnetic field where the hot action is, so hotter quicker tone.....
__________________
Old 06-06-2009, 10:58 PM   #14
Might be interesting to make one coil formvar and the other PE. We'll see how it goes...
Old 06-07-2009, 01:22 AM   #15
Possum's Avatar
Yeah have done that too...
__________________
Old 06-07-2009, 02:10 AM   #16
Supporting Member
I did an 8.2K 42PE PAF style pickup on the Leesona 102 and a 8.2K heavy Formvar PAF style pickups with the same coil offset, wound on the Leesona 102... And the heavy Formvar pickup was a mud machine on the low end compared to the 42 PE pickup.
__________________
www.throbak.com
JGundry is online now   Reply With Quote
Old 06-07-2009, 05:11 AM   #17
Possum's Avatar
Yeah its mostly because the coils are larger plus formvar seems to be a darker sounding insulation judging from the single black formvar I have and a neck pickup I wound with it. I did one with heavy on one coil and PE on the other it sounded OK, kinda confused, it didn't know what to be
This really brings into question the "formvar" Peter Green rewind on neck. I seriously doubt it was heavy formvar if it even WAS formvar at all. For all we know it was single 43 guage formvar, about the only thing that makes sense.....
__________________
Old 06-15-2009, 09:17 PM   #18
Electricdaveyboy's Avatar
Smile Formvar Neck Pickup on Pickupmaker Showcase
Hello Zang,
yes you can hear a formvar neck position pickup in the video I posted on the showcase site- it is my Greeny Blues Set.
You shall not wind it to hot - means go for less windings than the regular PAF PE type pickup.
Cheers
david
Electricdaveyboy is offline   Reply With Quote
Old 06-16-2009, 04:21 AM   #19
Possum's Avatar
The problem with that is that the Peter Green neck pickup is reputed to be wound to 8.2K If you wind one with heavy formvar to that and put it in neck it would sound like mud. WCR is the source for that supposed PG specs. I suspect that pickup was wound with regular PE. We'll probably never know for sure....
Other possibilities are that it was wound with only one bobbin and maybe it was single formvar. I mean when a humbucker goes dead it usually is only ONE bobbin not both, right?
__________________
Old 06-24-2009, 01:14 AM   #20
If it's that dark, it might make for some smoother sounding sub-8k bridge pu's. Hmmm....
44 AWG single FORMVAR or single film insulated..? mickmutante Pickup Makers 5 04-05-2009 07:10 PM
Anyone use heavy formvar? David Schwab Pickup Makers 12 03-21-2008 02:27 AM
Tonal Comparison Between PE and Formvar voodoochild Pickup Makers 14 12-07-2007 01:43 PM
44 single formvar kevinT Pickup Makers 3 03-30-2007 04:06 PM
making humbuckers franklin01 Pickup Makers 6 08-18-2006 06:12 PM
