Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 06-03-2009, 11:29 AM   #1
Supporting Member
SS rectifier & hum magic
I'd just like to confirm something as a result of trying out Merlin b's suggestion of series diodes with parallel caps - It actually makes the rectifier a lot quieter. For a FW rectifier, I used 2 x 1N4007s in series on each side of the HT, with 3kV (I know its overkill - could've used 1kV) .01uF cap in parallel with each diode (that's 4 diodes & 4 caps).
Just to satisfy my curiosity I tried the same amp (a 6G15 clone) with a standard 2-diode FW rectifier, and it was quite a bit noisier.
Needless to say the diode-cap trick is a keeper (where SS rectification is called for) - so there. JM2CW
(I realise its not a new revelation - but 'twas good for me)
__________________
Old 06-03-2009, 12:24 PM   #2
Supporting Member
Hi tw!
BTW how is it going down there? Hope you're fine!
Yep, AFAIK those caps help to smooth each diode' s switching transient, which ( of course ) is generated at mains frequency by each diode. This kind of transient is too brief a spike to be properly filtered by the following filter caps, due to their long time constant.
A good thing to remember when SS rectifiers are to be used, so thanks you for the "heads up" ( and, of course, thanks to Merlin b as well )
Cheers
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is offline   Reply With Quote
Old 06-03-2009, 03:11 PM   #3
guitician's Avatar
Those are called "Snubber" caps. If you use "Fast" diodes you don't have to use them.
guitician is offline   Reply With Quote
Old 06-04-2009, 12:03 PM   #4
Supporting Member
Yep, also called "Schottky" diodes ( after the name of a scientist, if memory serves me well )
__________________
Old 06-24-2009, 12:29 PM   #5
txstrat's Avatar
Well, lately I noticed a stronger hum in a DRII copy I built. The original design calls for those snubber caps, as well as double the value for the first filter cap.
My first filter is 47uF, the schematic shows a 40uF and a 80uF in parallel.
Do you guys think the hum can be notably reduced by correcting those two differences?
txstrat is offline   Reply With Quote
Old 06-24-2009, 01:51 PM   #6
Supporting Member
Hi Matt,
120 uF is almost three times as much filtering, so I think your 47 uF cap could be too small to properly filter the ripple, especially when the current demand tends to increase ( ripple is load-dependent ). Since we're talking about SS rectifiers ( so no worries about ruining a rectifier tube with too large a filter cap ) I'd consider some over-filtering ( 200 or even 220 uF ).
Over-filtering should help the amp's dynamic behavior as well as with ripple, especially on power chords, aggressive rhythmic playing and the like, because the large filter capacitance acts as an energy reservoir ready to be released when the output tubes ask for it.
As to the snubber caps, they kill the diodes' switching transients, and they cost so little that I'd give' em a try in any case
( unless you throw in Schottky diodes ).
HTH
Best regards
Bob
__________________
Old 06-24-2009, 08:26 PM   #7
Supporting Member
Yep they definitely reduce noise where you have 1N4007s. See the attached schematic (courtesy of valve wizard).
__________________
Old 06-25-2009, 06:17 AM   #8
Sir Cuitous's Avatar
What would be the "fast diode" equivalent to the 1N4007?
__________________
"The time I burned my guitar it was like a sacrifice. You sacrifice the things you love. I love my guitar."
- Jimi Hendrix
http://www.detempleguitars.com
Sir Cuitous is offline   Reply With Quote
Old 06-25-2009, 07:44 AM   #9
txstrat's Avatar
Quote:
Yeah, I'd like to know that too.
TW
Why'd you choose 10nF for your snubber caps? In the DRII schem there are 2nF. I believe if I use a bridge recto it would make no difference, would it?
Bob
I'll definitely try a second (80uF laying around) cap in parallel.
Old 06-25-2009, 08:59 AM   #10
A bridge rectifier is four diodes in a box, nothing more.
There are various fast recovery diodes to choose from. 1N4007 is a common general purpose diode - 1 amp 1000v - so match those specs. Take your pick. If I recall - and that happens less and less lately - UF4007 is a popular choice. I think I have FR107 in the drawer, along with some Moto types I don;t remember.
__________________
Old 06-25-2009, 09:20 AM   #11
txstrat's Avatar
Quote:
Hihi, yes I know that.
I usually use four single diodes setup properly.
My question was regarding the snubber caps value. The DRII schem shows 2nF with a brigde recto.
I was wondering if the value depends on the sort of rectifier since tubeswell uses 10nF with a FW recto.
Anyway, I might go for the UF4007 (thanks BTW) but they seem hard to find in stores round here. Might order them online.
Old 06-25-2009, 09:25 AM   #12
Supporting Member
2nF, 10nF, 100nF, doesn't really matter - whatever you can get in the 1kV-3kV ish rating
__________________
Old 06-25-2009, 10:16 AM   #13
oh.
Tubeswell has it, the difference in value was whatever the different engineers thought would be sufficient. Has nothing to do with the bridge being four diodes or a block bridge.
__________________
Old 06-25-2009, 11:02 PM   #14
Supporting Member
Well,
I could be wrong, and if so bear with me, ( my last two neurons just went to bed and they're peacefully sleeping at the moment ) but I think there are some limits that are not to be exceeded....if snubber caps are too large they could cause some AC to "bypass" the diodes due to their low capacitive reactance at mains frequency.
Xc=1/(2pi*F*C), so a 1 uF snubber cap at 50 Hz would behave like a 3183 Ohms resistor in parallel with the relevant diode ( 2652 Ohms at 60 Hz ), and the rectifier's functionality would be hindered, as a part of the "opposed" half wave would pass through.
Something in the 10 to 47 nF range could be in the ballpark IMHO.
FWIW in small applications like ours I've never seen snubber caps larger than 22 nF so far, though larger caps might be needed in "bigger" applications.
JM2CW
Best regards
Bob
__________________
Old 06-26-2009, 10:41 AM   #15
Supporting Member
Ok Bob that sounds scientific enough to make me a believer. Well done.
__________________
Old 06-26-2009, 11:07 AM   #16
Supporting Member
Hi again tw!
Scientific? Me? You gotta be kidding!
Cheers
Bob
__________________
Old 06-26-2009, 05:14 PM   #17
tedmich's Avatar
some love avalanche rectifiers like the 1N5062 for tube amp supplies; they have an internal snubber. The real hardcores use very spendy FRED, Stealth (Fairchild) and super fast diodes, but have reported some blown diodes because the spike handling is not as robust. These guys bypass EVERYTHING with a 1-3kV 1-10nF film caps, I saw one guy explain that the super fast diodes switched too fast and needed to be slowed down to decrease noise...?
Of course a MOV across the primary and a 10nF across the secondary of the PT are standard (good) practices IME
Another observation I second; the need to add diode snubbers, chokes and bypass caps is usually obviated by using more capacitor filtering (even the PV JSX has ~360uf on its B+)
tedmich is offline   Reply With Quote
Old 06-26-2009, 07:46 PM   #18
Supporting Member
Quote:
Originally Posted by tedmich View Post
.....the need to add diode snubbers, chokes and bypass caps is usually obviated by using more capacitor filtering (even the PV JSX has ~360uf on its B+)
Hi Ted,
( no disrespect intended ). Increasing filtering by itself helps in lowering ripple, and renders the amps more responsive and improves dynamics, but, unless the filtering caps are specially designed, they cannot respond well to fast transients/spikes or diodes' switching noise, due to their very long time constant, so these kind of disturbances could manage to slip through them.
This can be ( and sometimes is ) obviated by adding small capacitors in parallel, so that any residual "fast" disturbance can be eliminated.
Cheers
Bob
__________________
Old 06-26-2009, 08:06 PM   #19
Supporting Member
There's another thread here that discusses the use of snubbers etc.
Questions about Fast, Ultra-Fast, Hyper- Recovery Diodes
JoeM is offline   Reply With Quote
Old 06-30-2009, 03:22 AM   #20
tedmich's Avatar
Quote:
Originally Posted by Robert M. Martinelli View Post
Hi Ted,
Cheers
Bob
Wow Bob, you have become very sensitive! No offense taken and it would be ok anyway. You are correct, film bypass caps on ELs are very commonly done in high end audio amps, less so guitar amps (A Dr. Z clone is the last one I remember seeing) and they may well help clean up some noise inherent in a particular PS design. I am more dubious of their near constant inclusion in audiophile equipment and the stated benefits of added "sweetness" "enhanced sound stage" etc. etc. No obvious bad effect (save increased cost) so they are de rigeur' in some circles irrespective of actual quantifiable benefit, maybe like angioplasty. I am a cheap skeptic by default but may well come to believe with more data.
I do love film caps though...just bought 400 metal jacketed 470pF/630v polystyrenes for VERY cheap and may bypass everything with them...
Old 06-30-2009, 05:38 AM   #21
Supporting Member
Wow Bob, you have become very sensitive! No offense taken and it would be ok anyway...
Hi again Ted,
I am simply afraid of offending someone....I always try to improve my English ( and I hope it shows ) but I am aware of my limitations, there's always the chance for me to "say" something in an unclear or "wrong" manner, so I thank you for your kind words .
Cheers
Bob
__________________
Old 06-30-2009, 08:12 AM   #22
Supporting Member
FWIW I used the snubber caps in a stand-alone reverb unit that had a FW SS rectifier and I tried the unit with and without the snubber caps, and it was definitely quieter with the snubber caps - perhaps more noticeably so because it was a reverb unit, and as such, more sensitive to hum sources.
__________________
Magic Eye cortezthekiller Theory & Design 3 05-19-2009 06:09 PM
Magic Eye level indicator - where to connect it TDS Theory & Design 2 01-27-2009 09:20 PM
Magic turn number for humbucker PU! fuzzman93 Pickup Makers 23 01-27-2008 10:59 PM
Bridge rectifier vs. two-diode rectifier????????? anson Theory & Design 3 08-11-2007 11:03 PM
Selling Magic 2204 Copy-ebay Mouthurst Flea Market 1 12-31-2006 04:07 AM
