| Music Electronics General discussion about music electronics |
| | #1 |
| Learning Aid - resistors
I found this in Embedded Electronics Journal, and it may help you learn the resistor color codes. Graphical Resistance Calculator Set the colors on the resistor image and it tells you the resistance. Very simple.
| | #2 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
There are dozens of mnemonics for remembering the colour code, most of them un-PC or even unprintable. Electronic color code - Wikipedia, the free encyclopedia The one I remember ends "... But Virgins Go Without"
__________________ "Ohhhh miracle bulb shines feebly" |
| | #3 |
| Senior Member Join Date: Aug 2007
thanks for the link. Now if I could just tell what color the bands on the resistors really are? The bands mostly all look blurry and sort of mud colored to my eyes these days. best, mike |
| | #4 |
Yep there are lots of memory aids. I Have hired and fired technicians over the years, and at interview, one of the first things I do is check the general knowledge, "Here, read this color code." I had a guy once looked at the resistor I handed him them started reciting aloud, "Our bad boys..." When A was a kid, I just learned them, I never had a mnemonic. I remember yellow/purple was the first pair I managed to internalize. I knew that was 47 even when I couldn;t quite remember what blue/gray was. And it didn;t take long for the others to fill in, until one day I just knew them. But I did have - aside from the chart in a book - a little cardboard resistor calculator things that worked just like this thing I have linked to above. You turned three little cardboard wheels so the right color appeared in an opening in a picture of a resistor. Then numbers appeared in other openings. I used to look up the ones I was not sure of. Like green. What is that darn green anyway?
| | #5 |
| Senior Member Join Date: Oct 2007 Location: Tucson, AZ
| ...ours (USN) ended with "...Violet Gives Willingly..." and the tolerances were: "...Get Some Now..." for Gold(5%), Silver(10%), None(20%). ...not PC, but VERY rememberable, for sure!
__________________ ...and the Devil said: "...yes, but it's a DRY heat!" |
| | #6 | |
| Supporting Member Join Date: Jun 2008 Location: Italy
| Quote:
Well, according to what you and Steve said, Sigmund Freud was definitely right !! Cheers Bob
__________________ Foolproof equipment is hard to design, because fools are VERY ingenious... | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| how to start learning amp repair have some nolage | fatcatsambo | Theory & Design | 5 | 11-23-2009 06:00 AM |
| Learning scales & chords | Don Moose | Lobby | 2 | 02-27-2009 09:33 PM |
| Learning the LCR Meter | voodoochild | Pickup Makers | 7 | 02-06-2009 03:10 AM |
| Learning LT Spice | lowell | Theory & Design | 9 | 11-21-2008 11:11 AM |
| Advice for learning | jeremymiller | Maintenance, Troubleshooting & Repair | 6 | 10-02-2008 02:01 AM |
