| | #1 |
| Member Join Date: Feb 2007
| Amp that uses 6AQ5 tubes?
Do you guys know if there is a guitar amp that uses 6AQ5 miniature 7 pin output beam tetrode tubes?
| | #2 |
| Senior Member Join Date: Jul 2007 Location: Charlotte, NC
| 6AQ5 amp
There are a few. Gibson Scout 17-RVT uses 6AQ5 with 305v on the plates. With respect, Tubenit |
| | #3 |
| Member Join Date: Mar 2009 Location: Seattle, WA.
| 6AQ5 output tubes
The Gibson Crestline GA-5 Skylark amps use 6AQ5's in pairs.
| | #4 |
| 6AQ5
This is a version of DaGeezer's Little Wing amp that originally used 6BM8 tubes. I drew up this schematic but never got around to building the amp. I have a layout for it also. Should use a 270 ohm cathode resistor for the 6AQ5's, I think. (per Gibson schematics) With respect, Tubenit Last edited by Tubenit; 06-08-2009 at 02:30 PM. |
| | #5 |
| 6AQ5 Blues Amp
Ok, I also found another schematic that I drew up some time ago and have built as an amp. It has a layout with it also. I think the value on the cathode attenuation resistor may be incorrect? I may need to be 540 ohms for each one individually? (or something close to that?) With respect, Tubenit Last edited by Tubenit; 06-08-2009 at 02:31 PM. |
| | #6 |
| 56T with 6AQ5
I built the 56T with EL84's. It's perhaps the most touch sensitive amp I've played? I think a version of it could be done with 6AQ5's, but have not built one. Check for errors in the schematic. With respect, Tubenit |
| | #7 |
The early versions of Fender's Musicmaster Bass amp used 6AQ5's. Very nice amps!
| | #8 |
| Junior Member Join Date: Jul 2008
| Micro Champ
Adam Alpern has one with a single 12A_7 and single 6AQ5. I built one and connected it to a Weber 8" speaker and called it a harp amp. It sounded good to me.
| | #9 |
| Member Join Date: Apr 2007
The Gibson GA5T (first 'Crest' version) used twin 6AQ5s as did the Guild 66J. There's also a drop-in substitute, the 6005. J
| | #10 |
| Junior Member Join Date: Oct 2008
Gentlemen , we tried a SE 6AQ5 amp with the 6U8 preamp , http://www.wattkins.com/node/15993 ... The amp sounded good , but had a somewhat "ratty quality" to the tone...tried many changes , no luck ... even went with higher V PT ... same thing ??? ... You guys have any idea what could be causing that ???
| | #11 |
OK, we're now working on a 6AQ5 PP amp ... Looking for a suitable PT to supply the necessary 250-275 V at the plates... You guys have any preference ???
| | #12 |
| Member Join Date: Feb 2008
Here's a thread discussing a 6aq5-based tweed deluxe type clone that I built a while back. . . . 6AQ5-Based 5e3 Guitar Amp Build |
| The Following User Says Thank You to Johnrcurry For This Useful Post: | StarGeezers (11-17-2009) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6AQ5-Based 5e3 Guitar Amp Build | Johnrcurry | 5 E 3 | 16 | 04-10-2009 03:53 PM |
| 6aq5 to 6v6 conversion gibson ga-17rvt scout | mulletman | Mods & Tweeks | 5 | 05-26-2008 02:24 PM |
| 2 x 6AQ5 pushpull with 6X4 rectifier question | Pedro Vecino | Theory & Design | 3 | 05-23-2008 01:31 AM |
| 6AQ5 vs. 6BQ5/EL84 | EETStudent | Theory & Design | 13 | 05-15-2008 10:39 AM |
| 6AQ5 substitutions | EETStudent | Maintenance, Troubleshooting & Repair | 3 | 02-12-2008 05:29 PM |
