Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders
Old 06-07-2009, 03:01 AM   #1
Supporting Member
5F6A with Trem and verb experiment
The schemes and ideas came from this thread (which has gotten too long to add new stuff to easily).
Tweed Bassman / Deluxe w/ reverb. any opinion?
I eventually settled on version 12 something-or-other, and started work on the chassis a few weeks ago and yesterday did some more (fitted up the iron and made the main filter board & dog house) and today the weather looks suitable to do some more (- whatever the weather ).
Chassis is 65 cm long (and will have 11 knobs and 6 pre-amp tubes). Its another combo, this time with 2 x 25W greenbacks - more like a JTM45/bluesbreaker than a tweed bassman - but they're all just tweed bassmen right?. (zhyla has inspired me to try a different finish on the chassis, so I got some lazertran and enamel paint, and I'm experimenting with different finishes on some off-cuts of ally - more on that as time passes)
__________________
tubeswell is online now   Reply With Quote
Old 06-07-2009, 01:04 PM   #2
Supporting Member
Cab started
75cm wide 50cm high 23 cm deep - but the same 'ole white pine. The new 'innervation' for me is a 3/4" slant on the front (I try to make at least one little improvement with each amp ). This is going to seriously cramp up my amp cupboard (my stuff is already overflowing into the hallway)
__________________
Old 06-07-2009, 03:16 PM   #3
txstrat's Avatar
Man, that all looks great. Can hardly wait to see more. Should I wish for bad weather?
txstrat is offline   Reply With Quote
Old 06-09-2009, 08:03 AM   #4
Supporting Member
routing finished on cab
ready to make the baffle (front fitting baffle)
__________________
Old 06-09-2009, 08:40 AM   #5
looking good. curious how it will sound with the greenbacks in an openback cab.
black_labb is offline   Reply With Quote
Old 06-09-2009, 10:18 AM   #6
Supporting Member
I'm using a fairly beefy Pt and OT and a mixture of mustard caps and orange drops for the coupling caps, so I'm guessing it will sound something like a JTM45/bluesbreaker-cum-tweed bassman (with a deepish 'verb and bias-vary trem) if that ain't too much of a bastard - but my guess could be wrong
I put a 20W greenback in an open back combo (5G9) I built last year and it smokes
__________________
Old 06-17-2009, 09:39 PM   #7
Supporting Member
Progress update
Got the main board made and fitted (including the mounting board for the bias trimpot. Just the socket mounting to come and a few more holes, then I'll take it all apart and finish the chassis (somehow - haven't decided whether to go for a polished natural metal look this time, or a painted decal 'd look)
Also wired in the filter board, and cut some carry-handles in the cab sides for lugability
__________________
Old 06-21-2009, 12:56 AM   #8
Supporting Member
Baffle
Got the baffle (3/4" ply) done yesterday (bar covering). I didn't know how far apart to put the greenbacks, so the holes ended up 3.25" apart (so the speaker centres are 14.25" apart) - WTF.
__________________
Old 06-21-2009, 08:58 AM   #9
Woah, thats a big cabinet. Even for a 2x12. Should sound big too though. Serious eye candy. How do you plan to finish? Natural, tweed or tolex?
And how are you coupling the verb into the circuit???
Chuck
Chuck H is offline   Reply With Quote
Old 06-21-2009, 11:41 AM   #10
Supporting Member
Chuck
Hi Chuck
I've got heaps of black & white gingham tweed from previous builds
As far as the verb goes, see the version 12 schematic in that thread at the beginning
__________________
Old 07-04-2009, 11:28 AM   #11
Supporting Member
moving along
Got the cab covered and the G12s on board
Did most of the main board this avo
__________________
Old 07-04-2009, 08:13 PM   #12
txstrat's Avatar
Looks veeeery tidy. Great work.
Maybe in a couple decades when people talk about these amps of yours they'll refer to the gingham tweed era.
Old 07-05-2009, 09:31 AM   #13
vince76's Avatar
well done!
very nice build, I like it.
It seems my amp brother :-)
What kind of material did you use for the eyelet board?
Thank you,
Vincenzo
__________________
Happy to share
vince76 is offline   Reply With Quote
Old 07-05-2009, 12:37 PM   #14
Supporting Member
Quote:
Hi Vincenzo
I use 3mm electrical switchboard from an electrician supply wholesaler, and 4mm brass eyelets. The stuff is rated for mega-volts so its ideal.
__________________
Old 07-05-2009, 01:34 PM   #15
Supporting Member
Squeakin' on
Sockets in and heaters 90% wired in. The durafilm will come off after I've finished the engraving.
5A enough for the heaters ya'll reckon? (including the lamp)
Decided to do away with a standby switch this time - using the extra real estate for an HT fuse (beside the Mains fuse)
__________________
Old 07-08-2009, 12:08 PM   #16
Supporting Member
Quite a bit more work on the chassis today (and yesterday)
Engraving done, and wired in the input and output sockets, main sw, fuses, pilot lamp, PT, OT, choke filter board, and wired up the back of the main board and all pots trimmed and fitted. Weighs a ton.
__________________
Old 07-13-2009, 11:25 PM   #17
Supporting Member
1st attempt at chassis wiring finished. I put shielded cable in all the areas I think are sensitive signal paths, so we'll see. I have also omitted the rotary switch/impedance selector I had planned at this stage because it was too fiddly. I need to get a simpler one.
__________________
Old 08-05-2009, 11:53 PM   #18
Great project!
__________________
Seeking better tone for all
Jay Young
Roundtone Amplifiers
jyoung is offline   Reply With Quote
An experiment for gassy tubes 6267 Tubes (Valves) 15 03-11-2010 11:42 PM
Suggestions for Boogie Trem-O-Verb Problem? Steve L Maintenance, Troubleshooting & Repair 6 06-01-2009 07:10 PM
Bias vary trem in 5F6A type amp? tubeswell Tweed Builders 4 03-01-2009 12:53 AM
Earth Sound Research/Fender Twin Trem/Verb questions shiner555 Maintenance, Troubleshooting & Repair 4 11-26-2007 10:40 PM
Dual Rectifier Trem O Verb switching tonezoneonline Maintenance, Troubleshooting & Repair 11 08-22-2006 04:13 AM
