Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 06-11-2009, 03:22 AM   #1
Fender Twin Reverb -Amp HEAD ONLY
I just picked-up a Fender Twin Reverb -Amp that is a "head" only. It looks to be late '60's, as the Fender logo has the "tail" and there is no master volume or pull-out or anything. The guy who gave it to me (yes, gave for free) said it was a '67, but the little research I did makes me think it is between '68 - '71. My question(s): 1. Did Fender manufacture the Twin Reverb as a "head" only? I saw a Wikipedia posting that said they did and I saw some other random posting that made the reference that Fender never made the Twin Reverb as a "head" only. 2. It looks like the original head cabinet covering was re-covered over (a nice job) and I cannot find any, or feel any holes where I would guess the "piggyback" hardware would have been. If Fender did make Twin heads, wouldn't they have come with "Piggyback" hardware? 3. I play in a heavy rockabilly and surf band (a trio). I have just tested this amp through my single 12" speaker from my Mesa Boogie Mark I amp and it sounds great (the reverb mixed with a light tremelo is stunning). What are some speaker configurations I should test? 2-12's, 1-15", 4 - 10's? I play out about 4 - 5 times per month and volume levels change a lot depending on the room. I think it would look cool with one of those 2-12 Bandmaster cabs, but it probably needs some pretty heavy duty speakers because of all the power. 4. Lastly,I play pretty clean, but dealing with all that power may be a challenge in small rooms. Is there a "Powersoak," or speaker volume reducer that keeps the "highs" that I can get? Sorry for all the questions! I'm just so excited about the tone of this Twin!!! Thanks friends.
Thruxrocker is offline   Reply With Quote
Old 06-11-2009, 05:56 AM   #2
olddawg's Avatar
As far as I know the "head" version of the Twin Reverb was the Showman or Dual Showman. They were the same amp with a different name in a different box, but the chassis are the same. I would venture to guess that your amp is simply a regular old 2X12 Twin combo that was cut down to a head or put in a Showman box. That may have been the reason for recovering it. I played in a band for years with a guy that had the same thing. The Twin cab got damaged and he cut it down. It made it a lot easier to transport too. The classic Showman setup is two closed back 2X12 cabs. A lot of people used them back in the day, including Hendrix. Lear Jet loud and ice pick bright and clean.
olddawg is offline   Reply With Quote
The Following User Says Thank You to olddawg For This Useful Post:
Thruxrocker (06-12-2009)
Old 06-11-2009, 09:40 PM   #3
I'm with Olddawg, it sounds like you have a twin that has been cutdown into a head. Pretty common stupid modification.
When choosing the speaker cabinet, you should keep in mind that the output transformer is looking to see a 4 ohm load.
52 Bill is offline   Reply With Quote
The Following User Says Thank You to 52 Bill For This Useful Post:
Old 06-11-2009, 11:17 PM   #4
I saved/fixed a rusted out Showman recently. I run it w/ 1-12 EV, sometimes a 1-10 Weber, whatever....
"How many amps do you need, babe?" "Just one more." The OD Twanger 85 ...by Guitar Bob Ohsiek
These or Twins work fine with either one or two speakers, [heavy-duty of course, not some flimsy stock old Oxford, etc].
Baxtercat is offline   Reply With Quote
The Following User Says Thank You to Baxtercat For This Useful Post:
Old 06-15-2009, 05:14 PM   #5
Its possible the chassis could be in a bassman 100 cab or similar. Seen a few like that come thru here.
__________________
Gtr_tech is offline   Reply With Quote
1979 Fender Twin Reverb - can't turn off reverb pro1911a1 Maintenance, Troubleshooting & Repair 7 02-02-2009 02:40 PM
Reverb Issues on a Fender Twin Reverb womantone Repair and Restoration 15 09-26-2008 05:31 PM
Help me care for of my 72 Fender Twin Reverb jlonigro Maintenance, Troubleshooting & Repair 2 12-28-2007 10:48 PM
Fender Twin Reverb, too bright? shiner555 Mods & Tweeks 3 12-13-2007 04:54 PM
Fender Twin Reverb Dano Music Electronics 4 10-23-2006 10:56 PM
