Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps > Repair and Restoration
Old 06-14-2009, 04:35 AM   #1
Ampeg VT40 (top mount) ext. speaker problems
hey guys, i just dusted off my old VT40. it sounds fantastic, but it has a few issues that i can't figure out. i'm hoping you guys can tell me where to start.
so here's the first problem i'd like to iron out. when you plug something into the extension speaker jack, the whole amp mutes.
the combo 4x10's AND the extension speaker are supposed to project sound, but instead there's nothing from either. i check out the jack itself, and it is wired correctly. the 8 ohm tap is wired through the jack as though it were a switch, and the amp works fine without anything plugged in.
i do NOT have a scope at my disposal. otherwise, i am prepared to tackle this thing. any advice?
methodofcontrol is offline   Reply With Quote
Old 06-19-2009, 10:18 AM   #2
rf7
Supporting Member
rf7's Avatar
The extension speaker jack should switch the OT output from the 8 ohm tap to the 4 ohm tap, when a jack is plugged in. Is the 4 ohm tap wired to the jack correctly?
What is the impedance of your extension speaker? It should be 8 ohms for this application.
rf7 is offline   Reply With Quote
Old 06-19-2009, 02:08 PM   #3
got it all figured out. thanks for the reply, though. turned out the jack was corroded and a little out of shape.
i ran some sandpaper between the contacts and re-tensioned the tip connector and now it works like a charm!
i just assumed the problem was going to be more involved, so i posted prematurely. sorry about that. thanks again!
Old 06-23-2009, 02:55 PM   #4
Dave Curtis, dB AudioTech's Avatar
Replace the jack. It will fail again, sooner than later. Sandpaper takes off whatever plating was left, exposing the base metal. Next time you need to clean contacts, use a fresh dollar bill. You want to burnish/polish rather than scrape or sand. A shot of Deoxit goes a long way, too.
Dave Curtis, dB AudioTech is offline   Reply With Quote
Old 06-24-2009, 03:33 AM   #5
thanks for the tip!
i looked for a replacement, but i couldn't find the right jack.
so i figure i'll just have to tough it out for the time being.
Old 06-25-2009, 01:10 AM   #6
I think you're looking for the 13A:
http://www.switchcraft.com/products/..._schematic.pdf
Unless it just has one contact (like on my '70s VT22), then you want the 12A.
Old 06-25-2009, 02:54 AM   #7
thanks dave! i looked everywhere for that. i'll order one of those soon. you're correct, 13a is the model in question.
1974 Ampeg v4 "ext. amp out/ ext. amp in" TheGreatDepression Vintage Amps 6 02-12-2009 01:58 AM
Fender Bassman ext. speaker out dazzlindino Theory & Design 10 09-06-2008 05:58 AM
Ampeg vt40 combo old enough to smoke Rays Maintenance, Troubleshooting & Repair 6 06-10-2008 10:33 PM
Ampeg Vt40 Trouble methodofcontrol Maintenance, Troubleshooting & Repair 4 11-22-2006 12:27 AM
top mount ampeg VT40 methodofcontrol Maintenance, Troubleshooting & Repair 8 10-08-2006 05:35 PM
