| | #1 |
| Junior Member Join Date: May 2006
| 5D3 Deluxe as a harp amp...
...as suggested by Gerald Weber some time back. Changing the preamp power supply dropping resistor value, increasing coupling cap value, using a pot in place of the 56k resistor in the phase inverter, upping the cathode bypass cap value...any thoughts, or has anyone tried these mods? I have a 5E3 build, and am thinking of redoing it just to see how well it may work. TIA-
| | #2 |
| Junior Member Join Date: Nov 2006
Personally I like dropping the power in the preamp section – I rather drop the power and have a 12AT7 than running a 12A-Y/U- 7 with normal power. Changing the caps to 0.1 is cool as well (but in a 5E3 they are 0.1 already. Regarding the phase inverter : It does work ! But not as described in his article – sorry. But hey if you got the 5E3 it should take you no time to test it ! I’m sure a lot got to do with speakers, personal taste, etc. Good luck ! Hope to hear your side of the story ; )
| | #3 |
| 5D3 for harp...
Hi Morton- well, I received the few parts I neede to convert the 5E3 to the 5D3 today, and I have a variety of speakers on hand, so with any luck, I'll have something to post in a week or two (holidays...). Check out the other thread I have here discussing a design of Bruce Collins', which I'd REALLY like to try out. Thanks for your input, and happy holidays.
| | #4 |
| Member Join Date: Feb 2007 Location: Bålsta
| Edgar, fender or epiphone ,, always the same problem...
I got a sort of 5d3 amp. Its the same amp if i use novaltubes in preamp, but i could use oktaltubes if i want. Its called Edar and is a Swedish kit amp. Read about it if you want. http://www.ultimateguitargear.com/to...iews_edgar.htm I got the usual low mid/bass feedback problem.. Do anybody have a suggestion what to do to get rid of it? |
| | #5 |
OOOPS Sorry Edgar is a sort of 5E3...
| | #6 |
But now i modified it to a 5D3 and i have the unbalance pot. I uploaded some bad soundsamples at youtube. Search for arnenym and you find me.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Vacuum Tube Harp Amps! | Bruce / Mission Amps | Harp Amps | 33 | 01-21-2008 07:12 PM |
| David Allen amps built for harp? | hdawg | Harp Amps | 7 | 12-01-2006 11:48 AM |
| Anybody know anything about Kinder harp amps and mods? | Steve A. | Harp Amps | 13 | 11-21-2006 01:00 PM |
| Kinder Anti-Feedback+ box for harp | Steve A. | Guitar Effects | 1 | 08-17-2006 10:20 AM |
| Over driven Harp sound? | andrew4566 | Harp Amps | 0 | 06-10-2006 08:11 PM |
