Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 06-16-2009, 04:48 AM   #1
EL84 Wiring
I'm presently doing a build with an EL84 PP power section. From a schematic I have it appears that the cathodes (pin 3) are connected to another type of grid in the tube (suppressor?). Also, the pin numbers are not in the schematic so I'm not sure what pin that would be. The wiring diagram does not have the cathodes connected to any of the other pins. I'm wondering if this connection is internal and not one that I have to make myself? Pins 1, 6, and 8 are not used in the wiring diagram. From the research I've done all I've come up with is that 1,6, and 8 are internal connections.
Any help here would be greatly appreciated.
Thanks,
Greg
GregS is offline   Reply With Quote
Old 06-16-2009, 05:01 AM   #2
olddawg's Avatar
Thanks,
Greg
Here is an 18 watt Marshall schematic with pinouts. Hope this helps.
olddawg is offline   Reply With Quote
Old 06-16-2009, 03:24 PM   #3
Yes it does help as it shows the pin numbers and the internal connections of the tube. From this I can see that this other connection to the cathode is made internally in the tube and not something I have to worry about.
Thanks a lot,
Greg
Help with El84 SE design then1xon5 Theory & Design 32 12-13-2008 03:22 PM
EL84 and 6L6 in same amp - how to get 2 different B+? Hardtailed Theory & Design 12 07-11-2008 06:03 PM
EL84 Plate Voltage grandmasterflash213 Theory & Design 4 05-31-2008 10:47 AM
6AQ5 vs. 6BQ5/EL84 EETStudent Theory & Design 13 05-15-2008 09:39 AM
wich four el84? scole Build Your Amp 0 11-25-2006 02:58 PM
