Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 06-16-2009, 04:26 PM   #1
Acceptable Tolerance on AC resistance or Q
I was wondering what is a reasonable tolerance on this....
Occasionally, I will get a coil that reads way low and obviously has a short, but sometimes for example 9 out of 10 Strat coils will measure Q of 2.7, and one will measure 2.6.
I am handwinding, but if I can get 9 of 10 to measure exactly the same at 2.7, I am trying to figure out if the one at 2.6 has a flaw, or is just "acceptable tolerance".
Scott S. is offline   Reply With Quote
Old 06-17-2009, 01:43 AM   #2
Possum's Avatar
You can't spot coil shorts with Q readings. Use your AC resistance readings, find what a good strat coil reads, then if you get one where ACR goes up noticably you have a coil short or a short to the poles.....
__________________
http://www.SDpickups.com
Stephens Design Pickups
Possum is offline   Reply With Quote
DC Resistance after potting Chadheckler1 Pickup Makers 35 08-08-2009 10:57 PM
DC Resistance eggman6 Pickup Makers 2 02-22-2009 02:27 AM
Checking DC Resistance. Aka Nameless Pickup Makers 42 07-06-2007 11:20 PM
Acceptable variances for "matched" power tubes? Steve B Maintenance, Troubleshooting & Repair 31 10-12-2006 12:58 AM
Inductance vs Ac Resistance? jimi Pickup Makers 15 09-16-2006 01:45 PM
