Old 06-18-2009, 03:59 AM   #1
Question Hot Rod Deville 212
Hey, my R80 and R81 blew,
and I am planning on replacing them myself; however, does anyone know of any other symptoms/complications of this situation? Should I be looking at other faulty parts as well? What could have caused this?
diamond9er is offline   Reply With Quote
Old 06-18-2009, 09:01 AM   #2
Supporting Member
Hi and welcome to the forum!
R80 and R81 are there for hum reduction purposes, as they provide an "artificial" ( and balanced ) center tap to ground for the PT 6,3 VAC secondary winding ( heaters & pilot lamp ). If they have burnt open it's enough to replace both ( the amp works even taking those resistors out, though hum could be more audible ) as no other part should have suffered any damage IMHO. If they have shorted, the 6,3VAC secondary could have overheated, so you should check it for proper functioning.
As to the resistors' replacement, my advice would be to throw in a couple of 100 Ohm 1W resistors ( "half watters" are more likely to burn again ).
Hope this helps
Best regards
Bob
__________________
Foolproof equipment is hard to design, because fools are VERY ingenious...
Robert M. Martinelli is online now   Reply With Quote
Old 06-18-2009, 09:15 AM   #3
Little or no current flows through the hum resistors normally, there is no path for current to flow. When they burn up, it is almost always because a power tube failed. A high voltage shorted to the heater. Alternatively, if one of your power tubes has a broken off index post on the base, the tube may have been inserted in the socket the wrong orientation. That could also easily have shorted high voltage to ground through those resistors.
__________________
Hot Rod Deville 212 -- Blown Fuse Phranklee Maintenance, Troubleshooting & Repair 3 01-10-2009 04:55 PM
Fender Hot Rod Deville Rob Stmple Maintenance, Troubleshooting & Repair 5 11-24-2008 11:51 PM
Hot Rod DeVille 410 issue stevek Maintenance, Troubleshooting & Repair 3 11-21-2008 10:46 PM
Deville Hot Rod 212 fizzled out webzz Maintenance, Troubleshooting & Repair 4 08-12-2008 02:54 AM
Fender hot rod deville UsaGold91 Flea Market 0 04-09-2008 01:47 AM
