Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 06-20-2009, 02:23 PM   #1
Is a cap needed between MV - SE with bias?
I'm designing a single-ended amp with tremolo and variable bias. It's based on the princeton reverb circuit.
I've added a master volume pot before the grid (pin 5) of the 6V6, which also has a 220K connected to the intensity pot and bias board. This would have -35 volts.
I'm wondering if a coupling cap is needed to stop that DC (-35) from going onto the Master volume pot (via the wiper).
Thanks!!
__________________
See the birth of a 2-watt tube guitar amp - the "Dyno Tweed"
http://www.naturdoctor.com/Chapters/Amps/DynoTweed.html
PRNDL is offline   Reply With Quote
Old 06-20-2009, 02:53 PM   #2
Supporting Member
Yep anywhere you've got DC that would otherwise connect to a pot - its a good idea to put a blocking cap in between the DC source and the pot
__________________
Old 06-20-2009, 04:28 PM   #3
Easy enough to add it. -- thanks
__________________
Old 06-20-2009, 07:24 PM   #4
I'm wondering if adding a master volume before the output tube is a good idea in a single-ended amp.
Also, whether I it's advisable to switch to cathode bias.
Any advice is welcome!!
__________________
Old 06-26-2009, 04:29 PM   #5
Thanks!!
Without seeing the print, I'm thinking yes it does. Not that the voltage is going to harm the volume pot, but more so if the -35 volts is attached to the wiper of the pot, and then you turn the pot to zero, it could short out the bias voltage. Also, the bias voltage across the pot would make it very scratchy. Because of the low input input impedance to the grid of the power tube, I would start with a 0.1uF cap
-g
__________________
Gary Moore
Moore Amplifiication
mooreamps@hotmail.com
mooreamps is offline   Reply With Quote
Recapping. Bias trim Cap? Michael Allen Mods & Tweeks 12 12-07-2008 04:51 PM
DIY Bias probe - advice needed spheikki Theory & Design 8 07-22-2008 02:13 AM
question about bias cap values? texwest Maintenance, Troubleshooting & Repair 6 05-06-2008 11:24 AM
Is Bias Needed For A Super Champ??? superchamp1 Vintage Amps 1 02-02-2008 08:47 PM
Cap bypassed cathode bias vs fixed bias? Hardtailed Theory & Design 4 01-18-2008 08:39 AM
